B How do you multiply percents on paper
  • B
  • Thread starter Thread starter jim1174
    Paper
To multiply percents on paper, convert the percentage to a fraction by dividing by 100. For example, 5 percent is 5/100, which simplifies calculations. When multiplying, factor out powers of ten to manage zeros effectively; for instance, 5 million times 0.05 results in 250,000 after adjusting the decimal point. It's crucial to count the decimal places in both numbers to determine where to place the decimal in the final answer. Understanding these steps ensures accurate results when calculating percentages manually.
jim1174
5 million times 5 percent would be 5000000 X 0.05. When you do this on a calculator you get 250000 but when you do it on paper you end up with more zeros in the answer. When you multiply percents on paper what is the easiest way to figure out how many zeros go in your answer?
Mathematics news on Phys.org
When it comes to computing math by hand, I like fractions more than decimals.
5 percent is 5/100, so I'd multiply 5 million by 5 to get 25 million, and divide by 100 to get 250 thousand.
If you're getting more zeroes, you may be getting 25000000, but because it's 0.05 instead of 5, you need to shift the decimal point in your result two places to the left.
First and most important is that % means nothing else than divided by 100.
Next it is best to write such numbers by powers of ten: ##5000000=5,000,000 = 5\cdot 10^6##. Thus we have
5000000 \cdot 0.05 = 5 \cdot 10^6 \cdot 5 \cdot \frac{1}{100} = 25 \cdot 10^6 \cdot 10^{-2} =25 \cdot10^4 = 250,000
Likes Imager and FactChecker
Factor out the powers of 10 (move the decimal point) so that you can add or subtract exponents: ##5000000 * 0.05 = 5*10^6*5*10^{-2} = 25*10^{6-2} = 25*10^4 = 250000.##
EDIT: I'm too slow. ;>)
It is a rule of decimal long hand multiplication. Count all the places to the right of the decimal point in both numbers, in your case 2 places(0.05) and 0 int the original number. the answer has to a decimal point 2 places to the left.
example: 0.125 x 1.34 = 125 x 134 = 16750 now we need to add 5 decimal places: 0.16750 or 0.15675
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
