How Do You Prove Limits at Infinity?
goody1
Hi, can anybody help me with this two limits? I have to prove them by the definition of limit. Thank you in advance.
View attachment 9630 View attachment 9631
  • Limit expression: lim as x approaches infinity of (x - 1)/(x + 2) = 1.
  • Limit expression: lim as x approaches -1 of -1 divided by (x + 1)^2 equals negative infinity.
Hi Goody, and welcome to MHB!
To prove that $$\lim_{x\to\infty}\frac{x-1}{x+2} = 1$$, you have to show that, given $\varepsilon > 0$, you can find $N$ such that $$\left|\frac{x-1}{x+2} - 1\right| < \varepsilon$$ whenever $x>N$.
So, first you should simplify $$\left|\frac{x-1}{x+2} - 1\right|$$. Then you should see how large $x$ has to be in order to make that expression less than $\varepsilon$.
To prove that $$\lim_{x\to-1}\frac{-1}{(x+1)^2} = -\infty$$, you have to show that, given $M$, you can find $\delta>0$ such that $$\frac{-1}{(x+1)^2} < -M$$ whenever $|x+1| < \delta$. That is actually an easier calculation than the first one, so you might want to try that one first.
goody said:
Hi Opalg! Do you think I got it correct?
Not quite, although you started correctly. The limit in this case is as $x\to\infty$, so you want to see what happens when $x$ gets large. This means that the inequality $\dfrac3{|x+2|}<\varepsilon$ has to hold for all $x$ greater than $N$ (where you think of $N$ as being a large number).
Write the inequality as $|x+2| > \dfrac3\varepsilon$, and you see that this will be true if $x > \dfrac3\varepsilon -2$. So you can take $N = \dfrac3\varepsilon -2$. More simply, you could take $N = \dfrac3\varepsilon$, which will satisfy the required condition with a bit to spare.
