How do you remove water droplets inside watch?
  • Thread starter Thread starter chrisalviola
    watch Water
A user reported moisture inside their watch after washing clothes with it in a pocket and sought advice on how to remove the moisture. Recommendations included attempting to open the back of the watch to allow it to dry, though some users noted they couldn't open it themselves. For valuable watches, consulting a local jeweler was advised. Alternative methods suggested included using silica gel packets in a sealed bag with the watch, placing the watch in a warm environment, or using a desiccator. Some humorous suggestions included unconventional methods like using a torch or placing the watch in water to mask the droplets. Overall, the consensus emphasized the importance of drying the watch properly and the potential for irreversible damage if moisture remains.
chrisalviola
I forgot to take my watch inside my clothes pocket and when I washed my clothes my watch formed some moisture and small water droplets inside, I let it dry under the sun for3-4 hours every day but still there's moisture inside, it seems won't go away. what do you recommend I should do?
I'd first try just popping the back off (where the battery is located) and let it sit for a few days to dry with the cover off so the moisture can get back out, i.e., don't wear it while trying to get it to dry.
thats the problem there I can't open the back plate.
If its an expensive watch I'd take it to a local jeweler or watch maker and see what they recommend.
If the watch is valuable, take it to a jeweler. If it's not, even the jewelry counter at a discount store can pop it open.
Edit: Great minds think alike.
ok will try to bring this to a local jeweler tnks, I was hoping there's a technique for these meybe in an oven or a dehydrator maybe.
The damage to the workings may be irreversible at this point and drying alone won't help.
If its a fairly inexpensive metal watch case, use a knife to pop the back of the bezel off. Just use the blade at the little rectangular spot on the back of the bezel. Its just like using a jewelers wrench.
Here's a photographer's trick: Find as many of those silica gel dessicant packages ("do not eat! Throw away!") as you can, and seal them up with the watch in a zip-lock bag and leave them in a warm place. As has been said, damage may already be done.
thats a good idea tnks.
If the drops are bothering you just put the watch in a glass of water until it is completely full of water and you won't notice the drops
:smile: When I saw your name replying to this, I was expecting the advice to be to heat the watch with a MAPP torch to evaporate out all the water. :wink:
I thought about that, but when I tried it on my watch I burned the heck out of my wrist
I'm dead. DoL. I've died. I'm dead.:snarf: Rofl::eek:
You are supposed to put the watch on your living-room carpet when you use a torch to dry it.
And then flip the square of carpet to cover the damage?
I see you've been following closely!
Go somewhere where they sell hearing aids and ask for the little container thing that extracts moisture out of small thing (like hearing aids). Buy one for like $10. If you put it in there every night, you'll never see droplets of water in your watch.
Putting a watch in a 120F or even 150F oven for a few hours should dry it out without causing any damage. Be careful, though, and use a thermometer -- many household ovens do not properly indicate temperatures this low.
- Warren
Stick it in a desiccator filled with Dryrite. Wait until the dryrite turns pink. It will definitely work.
Remove the back cover and let it dry out. Replace the back cover when it is dry. You may need to clean the crystal if there are water spots after it is dry. There is also water in the interior of the watch which can cause real problems unless you really dry it out. Removing the cover is the fastest and surest way.
And then use your phone to post on PF how great it worked.
I will need to boost reception of the wi-fi signal. How can this be done?
My brother owns a clock/watch repair store. He said what Evo said about taking it to a jeweler. If it were his watch he would open the back(it will either screw off or pry off) and blow it with a hair dryer. He also says it would be best to remove the watch from the case but "BE VERY CAREFUL NOT TO BREAK THE STEM, SCRATCH THE COIL OR CIRCUIT."
