How do you separate iron from clay?
  • Thread starter thankz
  • Tags
    Clay Iron
In summary,-The red color of raw clay is due to the presence of iron.-Clay can be separated from iron by electrophoresis.-Bricks and porcelain are made from pure clay.-Steel can be produced in a smelter, but so can other grades of iron.
thankz
265
40
I'm assuming the reason raw clay is red is because of the iron content, how do you separate it. also is that why bricks are red? and is porcelain just pure clay? one more thing do smelters of iron (how?) also produce steel at their factorys, and if so is that steel also sold as ingots for further processing. one more thing I'm assuming the way you purify steel is thru magnetic induction. can someone show me an example of a machine that makes steel wire tia.
fyi I was watching cnbc and suddenly became interested in the manufacture of guitar string! :woot:
Likes Silicon Waffle
thanks greg, that answers my question about separating clay from iron, it's a combination of fractionation and electrophoresis which I'm a little familiar with after watching the discovery channel on the refinement of copper 99.99% pure for wire for electronics.
if someone else would like to take a shot at my other questions feel free. :smile:
Indeed. The paper I linked to is from 1969 so I imagine the process has been refined since then.
There's a lot of videos of it on youtube, but most wires are made by cold drawing in one form or another. Basically take some metal that's, say, 0.250" in diameter, pull it through a hole that's 0.245" in diameter. Rinse and repeat until you get to the thickness you want (with possible annealing steps to take out cold working damage). There's a lot more to it than I said industrially, but it's the basic idea.
There's a video of someone doing silver. You just keep on going through the smaller and smaller holes until you hit your desired diameter.
Edit: This is actually a pretty good video for a non-automated process.
Red bricks have an iron (II) oxide added. Same reason why you can get brown and yellow etc. Different metal oxide combinations, if you look in the old books on building and painting (I have one from 1951) they tell you what pigments give you what colours, and back then you bought iron (II) oxide and not "brick red" or whatever. You can get synthetic pigments too.
Steel-making iron can be produced in a smelter, but so can other grades of iron. Iron ore can come with different impurities, some good for steel (V, Ti) and some bad (Mg, Na), and what these impurities are will dictate what the iron ore's used for. At my job we process iron for steel making and sell it to be fired in a smelter at a grade to be used for steel frames. We don't have the capacity, money or materials to make it straight to steel. Plus, some use the ore as smelter fuel.
Probably should add, iron ores come in different deposit 'styles.' Most are iron (II) oxides, but iron (III) oxides, iron carbonates and other compounds do occur. Most iron ores in Australia are 'banded iron formations' where iron(II) and (III) are layered in sedimentary rocks, and these are large scale. Smaller deposits are in volcanic rocks, and metamorphosed volcanic assemblages called 'skarns.' So what the smelter does depends on the ore which depends on deposit style, and how ore is extracted depends on this too. I could go on and on if you want about different iron deposits...
thanks, I can research further if need be.
No worries thankz...let me know if you have any more questions.
1. How does the process of separating iron from clay work?
The process of separating iron from clay is known as magnetic separation. It involves using a magnet to attract and remove the iron particles from the clay. This is possible because iron is a magnetic material, while clay is not.
2. What equipment is needed to separate iron from clay?
To separate iron from clay, you will need a strong magnet, a container, and water. The magnet will be used to attract and remove the iron particles, while the container and water will be used to hold and wash away the clay particles.
3. Can any type of magnet be used to separate iron from clay?
No, not all magnets are strong enough to separate iron from clay. It is recommended to use a neodymium magnet, as it is one of the strongest types of magnets available.
4. How long does it take to separate iron from clay?
The length of time it takes to separate iron from clay depends on the amount of iron and clay present, as well as the strength of the magnet being used. Generally, the process can take anywhere from a few minutes to several hours.
5. Can the iron and clay be reused after separation?
Yes, the iron and clay particles can be reused after separation. The iron particles can be used for various purposes, such as in steel production, while the clay particles can be used in pottery or as a soil amendment.
  • General Engineering
  • Mechanical Engineering
16K
  • Astronomy and Astrophysics
