How do you solve a problem that says:
  • Thread starter Thread starter j0nath0n3
To solve for the standard form of the equation of a circle given the endpoints of a diameter at (0,0) and (6,8), first determine the center by averaging the coordinates, resulting in (3,4). The radius is calculated as the distance from the center to one of the endpoints, which is 5. The standard form of the circle's equation is then (x-3)² + (y-4)² = 25, where (h,k) represents the center and r is the radius. Understanding the variables h, k, and r is crucial for correctly applying the standard form. This method effectively leads to the correct equation for the circle.
j0nath0n3
Endpoints of a diameter : (0,0), (6,8)
It says write the standard form of the equation of the specified circle.
Anyone know how to solve this?
Hint: Start by finding the coordinates of the center of the circle. If you don't know the standard form for the equation of a circle, you'll have to look it up.
If you mean (x-h)^2+(y-k)^2=r^2
i know it i just don't understand how i would get
(x-3)^2 + (y-4)^2=25 that's what the back of my book tells me i just don't see how they get to it..
That's the right general equation; Look up what h, k, and r stand for.
H,K is X,Y
R is Radius
j0nath0n3 said:
H,K is X,Y
X, Y of what?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
