How Do You Solve These Physics Equations?
The discussion revolves around solving various physics equations, specifically focusing on finding variables such as Vl, V, t, and M from given formulas. Initial attempts at solutions for equations involving kinematics and energy were presented, but some were incorrect, leading to confusion about algebraic manipulation. A participant clarified their misunderstandings regarding transposition and the importance of performing the same operation on both sides of an equation. After guidance, they successfully solved the equations, confirming their answers and expressing gratitude for the assistance received. The conversation highlights the significance of understanding algebraic principles in solving physics problems.
jaimieee
a) Given: 2ad - Vf2 - Vl2 . Find Vl?
b) Given: KE = 1/2 mv2 . Find V?
c) Given: a= (Vf - Vl)/t Find Vl
d) d= 1/2 gt 2 find t?
e) ac= (mv2)r, find M?
sorry, i do not know what are relevant eqs.
i have answeres a,b,c but i do not know the rest.
1) Vl =v2 - 2ad
Vl= sqrt(v2-2ad)
2) v2 = (2KE)/m
V= sqrt(2KE)/m
3) Vf = Vl + at
Vl = V - at
Thanks.
1) Vl =v2 - 2ad
Vl= sqrt(v2-2ad)
2) v2 = (2KE)/m
V= sqrt(2KE)/m
3) Vf = Vl + at
Vl = V - at
Thanks.
Are you just trying to rearrange the equations? If you can do the first three, I don't see why you shouldn't be able to get the last two. Can you show what you've tried so far?
yes!certainly. and sure. i already have answers from the problems tho I am not sure if those are correct.:
1) Vl =v2 - 2ad
Vl= sqrt(v2-2ad)
2) v2 = (2KE)/m
V= sqrt(2KE)/m
3) Vf = Vl + at
Vl = V - at
4) d= (gt^2)/2
t^2= 2(gd)
t=sqrt2(gd)
5) m=v^2 - acr
:) hope you could correct if I've done it wrongly :D
No, 4 and 5 do not look correct.
For 4, you are trying to isolate t on one side of the equation. The first step is to multiply both sides of the equation by 2, which you have done.
What is the second step, for getting rid of the g on the right hand side?
yea i think that's wrong too. I'm a little bit confused with that. i was comparing #4 from the 2nd problem. but i think i wasn't able to get it. :D what do you think?
Hi jaimieee,
As I've already said your solutions for 4 and 5 are wrong. I was trying to guide you through 4 step by step, but you didn't answer my question...
oops. I'm sorry. hmm. do i need to apply rationalization? i don't know, i was lost on that part. T__T coz what i did is.
d= (gt^2)/2
then i transposed t^2 it became
-t^2 = [g(-d)]/2
then i divided both sides by -1 to eliminate the negative sign on t
so it became
(-t^2)/-1 = [g(-d)]/2/-1
so i got the reciprocal
t^2= -2(-gd) :D
then to eliminate the exponent i extracted a sqrt
t=sqrt-2(-gd)
that's what i did.
I meant this question here, specifically. How would you get rid of the g?
We started with:
d = ½gt2
Then we got rid of the 1/2 by multiplying BOTH sides of the equation by 2. The result was:
2d = gt2
Now, we need to get rid of the g so that the t will be left by itself on the right hand side. How would you do that?
transpose g to the left side so the equation becomes:
2d-g=t^2 :D
-t^2 = [g(-d)]/2
What do you mean, "transposed?" :confused: This step does not make any sense mathematically.
If you have an equation like:
this = that​
then if you are going to do something to that equation, you have to do it to BOTH sides of the equation. If you do something to only one side, then it will no longer be true that it is equal to the other side. Do you understand?
So, (for example) multiplying both sides of the equation by 2 would be allowed:
2*this = 2*that​
but clearly doing it to only one side would NOT be allowed:
2*this = that​
because this statement is clearly FALSE.
oops.this equation "-t^2 = [g(-d)]/2" is quite confusing. i was confused with that too. hehe.sorry
so it has to be equal. hmm. so i won't be applying transposition? sorry but i don't get it.
right i need to get rid of the g so what i did is transpose it to the left which caused its sign to change so this is the equation i formed:
2d-g=t^2 then i'll extract a sqrt
so t = sqrt2d-g?
this is confusing me. sorry
jaimieee said:
2d-g=t^2
This equation is not true.
It is not true because this is not a valid step. The reason is because what "transposing" something from the right hand side to the left hand side really means is subtracting it from both sides. For example:
a = b + c​
If I "move the c" to the left hand side, what I am really doing is subtracting c from BOTH sides of the equation like so:
a - c = b + c - c​
which results in
a - c = b​
I did something to both sides of the equation. That's why this step is allowed. I cannot emphasize this enough:
If you do something to an equation, you have to do it to both sides of the equation
It is important that you understand WHY this is a rule. Do you understand why this is a rule? If you don't do it to both sides, then it won't be an equation anymore, because one side will no longer be equal to the other.
For the sake of argument, what would happen if we "transposed" a g to the left-hand side? Well, as I explained above, "transposing the g to the left hand side" really means, "subtracting g from both sides." Doing that would result in the following:
2d - g = gt2 - g​
So, transposing (i.e. subtracting) is not helpful because it doesn't get rid of the g on the right hand side.
so ya. i get it. it needs to be equal so:
2d - g = gt^2 -g
and on the right side g-g is cancelled
the eq will be
t^2=2d-g
to eliminate the exponent, ill extract a square root
so the final answer is:
t=sqrt 2d-g?
so is it correct? :D:D:D:D
jaimieee said:
2d - g = gt^2 -g
No, the two g's do NOT cancel. Whoever assigned you these problems assumed that you understood basic algebra. Now, I don't wish to sound mean, but it is clear from what I have quoted above that you do not understand basic algebra. I will make one last effort to explain this, but I have to say that after that if you still do not understand, I cannot help you. It is not reasonable to expect somebody on this online forum to teach you algebra.
First of all, saying that the g's cancel is like saying that:
ab - a = b​
This is most emphatically NOT true.
ab - a IS NOT EQUAL TO b​
This should be obvious, but if you don't understand, then at least try plugging in example numbers so that you can see what I am saying is true
a = 3
b = 7
ab - a = 3*7 - 3 = 21 - 3 = 18 WHICH IS NOT EQUAL TO 7
What I was trying to say in my previous post is that subtracting g from both sides will NOT help. Look at the right hand side. The right hand side is multiplied by g. If something is multiplied by g, what operation could I do to that something to get rid of the g (hint: it would be something that "undos" the multiplication).
LOL. 2d - g = gt^2 -g < you i agree with that. my bad. the g's on the right side should not be cancelled. but on our algebra that's the way we were taught. We have Adv. Algebra and Analytic Geometry and I really don't have a problem with that. But the one you're telling me made me confused coz it's really different. But Thank you, i really appreciate and I'm learning.
so my final answer ,
t=sqrt 2d-g? is it wrong? :D
If that's the way you were taught, your teacher was incompetent. Starting with
d = 1/2 * g * t2
how would you get the t2 factor all by itself. Notice that the operations on the right side are multiplications, so to undo those multiplications you should not be thinking of doing subtraction. What operation is the opposite of multiplication?
ab - a = b​
a = 3
b = 7
hi Cepheid, I was wrong and i was able to get your point. We were taught about that transposition thingy but not at that case. Sorry, my bad. But I was able too see my mistake and I got a perfect score in my homework.
d= (gt^2)/2
my solution is:
i multiplied both sides by two to eliminate the denominator on the right side so it became:
2d=gt^2
then to eliminate g i divided G to both sides:
(2d)/g=(gt^2)/g
so the G on the right side is cancelled
(2d)/g=t^2
then extracting square root:
t=sqrt(2d)/g]
that's my answer and i got a perfect score so i believe it's correct :D.
on the 5th problem:
ac= (mv^2)/r, find M?
what i did is is multiplied both sides by r to eliminate the r on the right side so:
r(ac)=mv^2
then to eliminate mv^2 i divided both sides by mv^2 so:
[r(ac)]/v^2=[mv^2]/v^2
so i canceled mv^2 on the right:
m=(r[ac])/v^2
Thank you very much Cepheid! Efforts are so much appreciated. ^^ cheers.
d = 1/2 * g * t2
Division :D . Well my bad, I was wrong sorry for giving a false info. anyway i was able to get everything. thanks too. :)
d= (gt^2)/2
my solution is:
2d=gt^2
(2d)/g=(gt^2)/g
(2d)/g=t^2
t=sqrt(2d)/g]
on the 5th problem:
r(ac)=mv^2
m=(r[ac])/v^2
jaimieee,
It looks good to me! And you are very welcome. I think that you have now understood what I was trying to say.
Regards,
cepheid
