How do you take this complex conjugate?
AxiomOfChoice
What's the complex conjugate of
<br /> \frac{1}{\sqrt{1+it}}, \quad t \geq 0.<br />
Mathematics news on Phys.org
<br /> \frac{1}{\sqrt{1-it}}<br />
The key is that for all complex z, z \overline{z} = |z|^2 so that \overline{z} = \frac{|z|^2}{z}
You can see this since (a + bi)(a - bi) = a^2 + b^2Now |\frac{1}{\sqrt{1+it}}|^2 <br /> <br /> = \frac{1}{|1+it|}<br /> <br /> = \frac{1}{\sqrt{1 + t^2}}
since abs commutes with multiplication, division, and exponentiation.
and so \overline{\frac{1}{\sqrt{1+it}}} <br /> <br /> = \frac{\frac{1}{\sqrt{1 + t^2}}} {\frac{1}{\sqrt{1+it}}} <br /> <br /> = \frac {\sqrt{1+it}} {\sqrt{1 + t^2}}
(edit)
Oops of course pmsrw3 is correct, and that's the same answer as mine but a lot easier! I'd delete my response but I don't want to waste all that TeX!:smile:
(Don't forget about branch cuts! A little bit of care must be used to ensure that the function and its proposed conjugate make consistent choices of principal value)
It works out OK in this case :-) I did actually think about that. If you picture the operations on the complex plane, it's pretty easy to see.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
