How do you the find magnitude and x component of a vector?
To find the x component and magnitude of vector A, it's essential to recognize that the vector -5.2 A has a magnitude of 47 m and points in the positive x direction. The x component can be calculated using the formula Ax = magnitude × cos(θ), where θ is the angle of the vector. Since the vector points along the x-axis, the angle is 0 degrees, making Ax equal to the magnitude of 47 m. The magnitude of vector A remains 47 m, as it is not affected by the negative sign in -5.2 A. Understanding these components is crucial for solving vector problems effectively.
egadda2
The vector -5.2 A has a magnitude of 47 m and points in the positive x direction
What is the x component of vector A?
What is the magnitude of vector A?
You seem to have missed two important sections:
egadda2 said:
2. Vector A = Ax + Ay
Ax = magnitude X xi
Ay = magnitude X yi
3. I don't know how to start.
any way to provide the diagram?
Try starting by figuring out how long A is, and in what direction it points.
Welcome to PF!
Hi egadda2! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Ax = magnitude X xi
Ay = magnitude X yi
That's very confused :redface:
you mean A = Ax x i + Ay x j.
ok, so in this case Ax = … ? :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
