I How does a band pass filter increase the time of arrival of photons?
Daniel Petka
TL;DR Summary
If a very short (laser) pulse attenuated to single photon intensity passes through a narrow band pass filter, do the photons get detected at random times?
Here is my thought experiment: Let's say I attenuate a very short laser pulse to single photon intensity. Due to the uncertainty principle, I know the time of arrival of the photons, but not their energy. So let's reverse that by splitting the pulse in its spectral components with a diffraction grating and passing the spectrum through a slit. The photons that pass through the slit will have a defined energy, but not a defined time of arrival, because each new photon arrives on a random spot and so it's also random if it passes through the slit. This seems logical (kind of). But now let's pass the pulse directly through a narrow band pass filter instead. The photons should still appear randomly. Is that true? If yes, it's extremely counter intuitive. It's as if the band pass filter can delay a photon randomly. How does this happen, what's going on here physically? It has to be true because, well, Fourier Transform, but I don't get why.
The filter can the thought of as a "measuring apparatus", which induces a "collapse" of initial superposition (of states with different energies) into a state with well defined energy. The collapse is "nonlocal", in the sense that it does not respect the principle that wave cannot "change" faster than light. As always, the exact physical meaning of "nonlocal collapse" depends on the choice of interpretation (Copenhagen, Bohm, many worlds, ...).
Thank you for the reply! This is probably one of those cases where intuition fails
Likes Demystifier
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
