How does a battery maintain potential difference in a discharge tube?
10 replies · 7K views
sudar_dhoni
sudar_dhoni said:
see the attachment
please explain the function of battery and ground in the picture
my doubt was that in discharge tubes the 2 plates are connected to some voltage source
let it be battery for instance see the fig in this case between the two plates there is empty space then what does the battery here do
does it send electrons to cathode which deposits on it and the cathde induces +charge on the anode and electrons return back
that is my doubt am i right or wrong
but when i consulted my physics teacher he told me that it can't induce to such long distances , he told that what happens is that electrons in anode are attracted by +terminal of the battery and when they reach the +terminal they repel the electrons in the - terminal which goes to the cathode as a result of repulsion
my main doubt is what is the meaning that battery maintains potential difference i can't understand this term can any1 explain in terms of charge movement (not mathematical)
also i read in
http://hyperphysics.phy-astr.gsu.edu/hbase/HFrame.html
about ground reservoir analogy i can't understand these lines
THE GROUND PROVIDES REFERRENCE VOLTAGE.THE GROUND CAN SUPPLY CHARGE TO CIRCUIT BUT ITS MAIN FUCTION IS TO HOLD THE VOLTAGE OF NEARBY WIRES AT THE VOLTAGE OF EARTH
PLZ ELECTRICAL ENGINEERS PLZ GUIDE ME ALSO I HAVE MANY DOUBTS IN RLC WHICH I WILL ASK IN NEW THREAD
The battery has some chemical reaction that pushes the electrons from the - terminal to the + terminal with a specific amount of energy. This amount of energy per electron is a voltage or in other words a potential difference.
i know that but in many books its written the plate is maintained at postitive potential
a battery is connected so that it sets up a potential difference
also why is that - terminal of battery is grounded in van de graff
in van de graff current can't flow from battery since it is not open circuit
in many cases circuits will not be complete as in discharge tube vacuum tube.In these cases battery can't supply current then what else it does
if u answer it maintains potential differece please tell me the meaning of it and please explain about my grounding doubt as mentioned in this same quote
That is not exactly correct. If the negative terminal is grounded (0 Volts by definition) then the positive terminal will have a positive potential. But you could just as easily ground the positive terminal in which case the negative terminal would have a negative voltage of the same magnitude as the positive terminal did previously. It really is a potential difference that a battery supplies.
Which figure? You have three figures showing two completely different kinds of devices.
I don't know what he meant by this. Electromagnetism has no range limitation, although the field of a point charge falls off as 1/r². It gets weaker over distance, but it never stops.
thats what i want to know the meaning behind what u have stated above (physical meaning like previously u told that voltage is energy gained or lost by unit charge)
"The battery has some chemical reaction that pushes the electrons from the - terminal to the + terminal with a specific amount of energy. This amount of energy per electron is a voltage or in other words a potential difference." the electron has higher energy at one site and 0 energy at the other.
like that i also what the meaning of what
Which figure? You have three figures showing two completely different kinds of devices.I don't know what he meant by this. Electromagnetism has no range limitation, although the field of a point charge falls off as 1/r². It gets weaker over distance, but it never stops.
first i was referring to discharge tube
next i wanted u to explain the role of battery in van de graff
OK, so basically a battery does work on an electron as it moves it from the + terminal to the - terminal. For example, in a car battery the chemical reactions do 12 eV of work on each electron resulting in a potential energy increase of 12 Joules for every Coulomb of electrons moved from the + to the - terminal. Or 12 Joules/Coulomb is 12 Volts.
The ground is just an arbitrary place that you call 0 Volts. In other words, you set your potential energy at ground equal to 0. This is completely analogous to the fact that if you are working a problem involving gravitational potential energy (mgh) you can set your h=0 point anywhere you want.
I don't really know anything about van de graff generators, but I will try to answer about cathode ray tubes. Basically, you heat up the cathode until it is so hot that electrons begin to boil off the surface. Then, if you have negatively charged the cathode and positively charged the anode then the electrons will be repeled from the cathode and attracted to the anode by Coulombs law. They will accelerate gaining kinetic energy (measured in eV) equal to the potential difference (measured in V) between the anode and cathode.
i almost 99.9%got it
the one doubt that i have is in electronics the negative terminal is grounded which means according to u negative terminal is 0 volts
the grounding of - terminal is a way of representation of an arbitrary place that you call 0 Volts in this case u connect it with - terminal to show that - terminal is at 0 volts that is the unit charge has no energy at 0 volts
am i right did u get to my point?
