How Does a Canister's Speed Change Along a Frictionless Incline?
The problem involves a spring on a frictionless incline, where a canister is compressed against the spring and released. The discussion focuses on determining the speed of the canister at two points: when the spring returns to its relaxed length and when it reaches the bottom of the incline. The subject area includes concepts of energy conservation, potential energy, and kinetic energy.
  • Participants discuss the application of energy conservation principles, questioning the relationship between height and velocity. There are attempts to derive expressions for velocity based on energy equations, with some participants expressing uncertainty about their calculations and assumptions.
Participants are actively engaging with the problem, sharing their calculations and questioning each other's reasoning. Some hints have been provided to reconsider the impact of height on velocity, and there is a recognition of potential errors in calculations. The discussion remains open, with no explicit consensus reached on the correct approach or solution.
There are mentions of potential confusion regarding the angle used in calculations and the treatment of height as positive or negative, indicating a need for clarity on reference levels and assumptions in the problem setup.
Gold3nlily
In Fig. 8-44, a spring with k = 170 N/m is at the top of a frictionless incline of angle θ = 37.0°. The lower end of the incline is distance D = 1.00 m from the end of the spring, which is at its relaxed length. A 2.00 kg canister is pushed against the spring until the spring is compressed 0.200 m and released from rest. (a) What is the speed of the canister at the instant the spring returns to its relaxed length (which is when the canister loses contact with the spring)? (b) What is the speed of the canister when it reaches the lower end of the incline?
Image:
http://edugen.wiley.com/edugen/courses/crs4957/halliday9118/halliday9118c08/image_n/nt0051-y.gif
The answer from the book is:
(a) 2.40 m/s; (b) 4.19 m/s
Emec1 = Emec2
Us = 1/2 k x^2
kE =1/2 m v^2
Ug = mgh
h = sin@*D
@=37
k=170 N/m
D=1m
m=2kg
d=0.2m
returns to its relaxed length ?
My answer is close to the correct answer at 2.9m/s but I
think it should be closer...
Emec1 = Emec2
Ke + U = KE + U
0 + 1/2 kd^2 = 1/2mv^2 +mgh
h = sin@*D
1/2 kd^2 = 1/2mv^2 +mg sin (40)*D
mv^2= 1/2 k(0.2)^2 - (2)(9.8)sin (40)*1
v= sq(-16.79/2)
I also think I did something wrong b/c had to eliminate negative sign...
v= 2.9m/s
What could I have done differently?
u bottom = 0; b/c h = 0
Emec1 = Emec2
Ke + U = KEb + Ub
1/2mv^2 +mg sin (40)*D = 1/2mv^2 + 0
cancel "m" and multiply by 2
v^2 + 2g sin (40)*1 = v^2
2.4^2 + 12.5986 = v^2
v = sq(18.358)
v = 4.28 m/s
This is still very close to the right answer but slightly different. (I Used
the books value for velocity to calculate part B) Sigh, I wish I was good
at this...
Hi Gold3nlily! :smile:
(have a theta: θ and try using the X2 icon just above the Reply box :wink:)
Hint: if you increase h, will that increase v, or decrease it? :wink:
Hello Tim. Thank you for answering my question! :biggrin:
Thank you also for the tips to put [tex]\theta[/tex] and x2.
Okay, so do you mean that it would be
0 + 1/2 kd2 = 1/2mv2 - mgh??
This way when h gets bigger, more of the spring potential energy will have to go into KE to balance and then velocity would get bigger. Yes? That makes sense, but can I also think of h as being negative becasue the block is moving down? If I did that would it mean that I am supposed to set my reference level (y=0) at the top?
When I do it this way I still don't get the exact answer.
mv2= 1/2 k (0.2)2 + (2)(9.8)sin (40)*1
v = sq(7.99932) (YAY! this is real result!)
v = 2.83 m/s
(answer should be 2.4 m/s. Its closer, but am I making any other mistakes? ...I am not rounding any intermediates or anything.)
Thank you again Tim!
v = sq(7.99932)
How exactly do you get 7.99932 ? :confused:
v2= (3.4 + 12.5986)/2 = 15.99983/2 = 7.99932
(b/c the mass is 2 kg and i divided by that?)
v = 2.83 m/s
(just got up :zzz: …)
ah, those 2s are confusing you :redface:
you've left out a 0.2 at the end :wink:
(oh, and is it 37° or 40° ? :confused:)
  • · Replies 21 ·
