How Does a Helium Balloon Achieve Buoyancy at 30 km Altitude?
  • Thread starter Thread starter forcedphysics
    Density
A helium balloon with a total mass of 20 kg is designed to lift a 70 kg payload, achieving buoyancy at 30 km altitude where air density is 0.035 kg/m^3. To determine the balloon's volume, the buoyancy force must equal the total weight, which includes both the balloon and the payload. The buoyancy force is calculated based on the weight of the air displaced by the balloon's volume. By subtracting the payload's volume of 0.010 m^3 from the total volume, the necessary calculations can be completed. Understanding these principles is essential for solving buoyancy-related problems in high-altitude scenarios.
forcedphysics
a helium balloon, with a combined mass of the balloon and helium of 20kg, is used to lift a payload of 70kg. At an altitude of 30 km the balloon stops and remains stationary.
a. Explain
b. at 30km, the density of air os 0.035kg/m^3. What is the volume of the balloon assuming that the volume of the payload is 0.010m^3
can someone please help, i need to kinda have a idea for my quiz tomorrow
for the vlume i came up with v=m/density
v = 90/.035
v = 2571?
I think you should use the concept of Buoyancy Force to solve it..
Balance the buoyancy force and the total weight to get the volume of the balloon and payload, then substract the volume of payload..
At 30 km, the total force, weight and bouyancy, is 0. You know the weight so you can calculate the bouyancy force- you also know, or should know, that that is equal to the weight of air displaced by the baloon. You are given the volume of the baloon- what would be the weight of that volume of air?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
