How Does a Particle's Position Change with Acceleration in the XY Plane?
  • Thread starter Thread starter im4rheal
    Dimensions Motion
A particle starts at the origin with an initial velocity of 7.2 m/s in the positive y direction and experiences a constant acceleration of (3.0i - 2.0j) m/s². To determine the x-coordinate when the particle crosses the x-axis (y=0), both x and y initial positions are set to zero. The problem requires formulating expressions for the x and y positions over time and using substitution to find the solution. The discussion emphasizes the importance of correctly applying kinematic equations to solve for the x-coordinate. Understanding the relationship between position, velocity, and acceleration is crucial for solving this problem.
im4rheal
A particle leaves the origin with a velocity of 7.2 m/s in the positive y direction and moves in the xy plane with a constant acceleration of (3.0i - 2.0j) m/s2. At the instant the particle moves back across the x-axis (y=0), what is the value of its x coordinate?
vxf=vxi+axt
xf=xi+.5(vxf+vxi)t
xf=xi+vxit+.5axt2
v2xf=v2xi+2ax(xf-xi)
Are my x and y initial (0,0) because it says origin? Do I have to used to substitution as well?
Starting at the origin does mean that xi=yi=0, yes.
I'm not entirely sure what your second question means, but you should be able to formulate an expression for both the x and y position of the particle at any given time and then use substitution to find the answer.
