How Does a Toroidal Coil's Magnetic Field Change with an Air-Gap Insertion?
The discussion revolves around the magnetic field of a toroidal coil, specifically how it changes with the insertion of an air gap. The problem involves applying Ampère’s law and understanding the relationships between magnetic fields and flux in different regions of the toroidal structure.
  • Participants discuss deriving the magnetic field inside the torus and the total magnetic flux. There are attempts to relate the magnetic field in the core and the air gap, with some questioning the correctness of the equations presented. Others explore the implications of magnetic linearity and the relationship between B-field and H-field.
The discussion is ongoing, with participants providing insights and clarifications on the relationships between different variables. Some guidance has been offered regarding the assumptions that can be made about the fields in the core and the gap, but no consensus has been reached on the specific approach to part b of the problem.
Participants are navigating the complexities of magnetic fields in materials and air gaps, with some noting that the equations presented may not align correctly. There is an acknowledgment of the need for careful consideration of the areas involved in the calculations.
Aisling1993
A toroidal coil,with N turns of wire carrying a current I, is uniformly wound around a
toroidal core that has a mean radius a, a cross-sectional area A= ∏(d/2)^2, and is made of a linear, isotropic homogeneous material with relative permeability μr. You may assume that the cross-sectional diameter, d, is very much smaller than a, d < a.
a, Use Ampère’s law to derive a formula for the magnetic field B inside the torus, and hence the total magnetic flux through the toroidal solenoid
b, A narrow air-gap of width w is now made, by removing a small sector of the toroidal core, so that the gap is a fiftieth of the circumference of the toroid. Show that the magnetic field in this gap is given by;
B = μrμ0NI/ 2∏a - w + wμr
∫B.ds= B∫ds
flux= B*A
For part a I got B=μ0μrNI/2∏a
and The flux ,phi = B*A = μ0μrNId^2/8
b, μ0μrNI = Bc.dsc + Bg.dsg
where Bc is the magnetic field in the toroidal core and Bg in the gap. Dsc is the area of the core and Dsg the area of the gap
Any tips on where to begin with part b would be much appreciated,
Thanks
B=μ0μrNI/2∏a
Okay.
The right side is not B*A.
Good. What is the relation between B- and H-field in the material / in the air gap? You can assume that the field is perpendicular to the surface of the material.
Hello, thanks for helping, so now
Flux , phi = ∫B.dA = μ0μrNId^2/8
B=μ0(H + M) for the toroidal material but we have magnetic linearity so:
Bc= μ0μrHc and Bg=μ0Hg
where Bc and Hc represent the B-field and H-field in the toroid and Bg and Hg in the air gap.
but the total flux trough each area of the circuit must be the same
so Acμ0μrHc = Agμ0Hg
where Ac and Ag represent the cross sectional area of the toroid and air gap respectively.
So Hg = Acμ0μrHc / Agμ0
Is this the right direction? it gets quite messy after this point
Again, the left side and the right side are different things.
At some point, it gets interesting to consider a line integral along the toroid core...
16K
