How does air restistance affect a projectile?
  • Thread starter Thread starter lindsey0307
    Air Projectile
Air resistance significantly impacts the trajectory of a projectile, altering the optimal launch angle for maximum distance and hang time. While a 45° angle is ideal in a vacuum, the presence of air resistance typically necessitates a lower launch angle to counteract drag effects. This adjustment helps maintain a balance between vertical and horizontal motion, enhancing overall performance. The discussion highlights the complexity of projectile motion in real-world conditions, emphasizing the need for adjustments based on environmental factors. Understanding these dynamics is crucial for accurate projectile trajectory predictions.
lindsey0307
For maximum hang time & distance (with no air resistance) a projectile should be launched at an angle of 45°. However, when air resistance is present, how does this affect the angle at which the projectile is launched at (to achieve maximum hang time and distance)?
I would think that the projectile would need to be launched at an angle less than 45° since air resistance affects the horizontal distance, but I don't believe I'm correct.
Thanks!
See pages C7, C8, and C9 in,
http://www.hnsa.org/doc/firecontrol/partc.htm
The rest of the booklet is an interesting read.
