How Does Charge Distribution Affect Electric Fields in Nested Conductors?
The discussion focuses on determining the electric field in different regions surrounding a solid conducting sphere and a concentric conducting spherical shell. It is established that the electric field is zero inside the conductor (r < r1) and between the sphere and the shell (r2 < r < r3) due to electrostatic equilibrium. For the region outside the shell (r > r3), the electric field is given by 3kQ/r. The conversation also touches on how the scenario would differ if both objects were insulators, emphasizing the need to consider charge distribution based on volume when calculating electric fields. Understanding these principles is crucial for solving problems related to charge distribution and electric fields in nested conductors.
theunbeatable
A solid conducting sphere of radius r1 has a total charge of +3Q. It is placed inside (and concentric with) a conducting spherical shell of inner radius r2 and outer radius r3. Find the electric field in these regions:
r < r1
r1 < r < r2
r2 < r < r3
r > r3
E = F / q
E = kq / R (for a point charge)
Because it's a conductor, I know that the electric field for r < r1 should be 0 (I also forgot the reasoning for this. I think it's because the charges are moving and somehow they cancel each other out?)
I'm confused on the other parts, though. For r1 < r < r2, I said that the electric field is 3kQ/r because the electric field from the sphere could be felt from that point. For r2 < r < r3, I said that the electric field was 0 for the same reasoning as r < r1, and I'm not even sure if that makes sense. Finally, for r > r3, I said it was 3kQ / r.
Careful. That formula is not quite right.
Except for that, your answers are fine. For electrostatic equilibrium, the field inside a conductor must be zero, otherwise charges would move until they canceled the field.
Oops, that should be R2 haha. So my answers were correct then?
And also, if both the sphere and the shell were insulators, would the answers be the opposite? Like for r < r1, the answer would be 3kQ/(r12)?
Yes, except as noted.
Not exactly. If the sphere were a uniformly charged insulator, then the field at any point within the sphere (say at r = ra, where ra < r1) would only depend on the charge within the region 0 < r < ra.
Are you sure that E = kq / R (for a point charge) is correct?
So it would have to be 3kQ/(r2) then.
No. 3Q is the total charge of the sphere. All you want is the charge within r.
Since r is an arbitrary length that is less than r1, how would we determine what the charge would be?
If the sphere were uniformly charged, then the charge would be proportional to the volume.
To find the charge contained within a sphere with radius less than ##r_1##, you will need to use the volume charge density of the sphere, where ##dq = \rho dV##
That makes sense. Thanks for the help everybody!
