How Does Finesse Influence the Performance of a Fabry-Perot Interferometer?
  • Thread starter Thread starter ayesha203
    Interferometer
The discussion focuses on designing a Fabry-Perot interferometer that achieves a transmission of T = 1 for light at 499 nm and T ≤ 0.01 at 500 nm under orthogonal incidence. The challenge lies in determining the necessary finesse to meet these transmission specifications while maintaining the same optical path length. Participants emphasize the importance of providing a clear problem statement and initial attempts to facilitate effective assistance. The calculations indicate that achieving a thickness of 249.5 nm is impractical due to the sensitivity of the transmission to slight wavelength variations. Overall, the conversation highlights the complexities involved in designing high-finesse optical instruments.
ayesha203
Design a Fabry perot interferometer, that provides a transmission of T =1 for light with λ1 = 499nm under orthogonal incidence and a transmission for λ2 = 500nm of T≤0.01 (without any further maxima in between). How big has to be the finesse?
Draw the transmission curve of several Fabry - Perot interferometer with this particular geometry (i.e. the same optical path length) for different finesse - values of F-1, 10 and 100 in the range from 498 nm to 501nm.
hello Ayesha,
Welcome to PF. You have seen something come by that looks like
Increase your chance to get a response!
• Use the template provided
• You must show your attempt at solving the problem
• Write the text of the problem here, not in an attachment or an image.
• Use an interesting and descriptive multi-word title
• Be comprehensive and clear with your message
• Be friendly and courteous
• Use correct spelling and grammar
You have done your best at 1.) and it's quite understandable. The deal is that you help us helping you by providing some hints as to where you are and where you have difficulty by using 2. and 3. The basic idea of PF is that you are done a bad service if someone else does your homework, but that you can learn a lot with a few questions and hints.
Good luck!
I have tried to solve the above question in the following way:
T = 1 for λ1 = 499nm
T ≤ 0.01 for λ2 = 500nm
for orthogonal incidence : Δs = 2nd, n = 1
Δs = m (λm)
m=1; n=1
d= λ1/2 = 249.5 nm
and i couldn't solve further...
Please help :)
It will be difficult to build such an instrument. 249.5 nm is too small, and a deviation of +0.5 nm would already let the 500 nm through with the same T. A hair is 50 μm !
You need an expression for the transmission of such a thing as a function of the wavelength. Nicely to be accommodated under 2): relevant equations...
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
