How Does Friction Affect the Speed of a Box on Different Surfaces?
  • Thread starter Thread starter Awwnutz
    Block Friction
The discussion revolves around the effects of friction on the speed of a box sliding across different surfaces. The problem involves a box initially moving at a speed of 2.8 m/s on a frictionless surface, which then encounters a rough surface with a coefficient of friction of 0.7. Participants are tasked with determining the distance required to stop the box and the speed of the box after traversing a shorter distance on the rough surface.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the Work Energy Theorem and the role of friction in energy conservation. Some express confusion about setting up equations correctly, particularly regarding the signs of forces involved. Others question the accuracy of their calculations and the values being used in their equations.
There is an ongoing exploration of the problem, with some participants successfully finding answers to part (a) while others continue to struggle with part (b). Guidance has been offered regarding the setup of equations and the treatment of friction, but no consensus has been reached on the correct approach to part (b).
Participants are working under the constraints of the problem's parameters, including the initial speed, the coefficient of friction, and the lengths of the rough surface being considered. There is a noted discrepancy in the lengths discussed, with some participants referencing different values for the distance over which the box travels on the rough surface.
Awwnutz
http://img522.imageshack.us/img522/3064/physicsblockfx4.gif
A box slides across a frictionless floor with an initial speed v = 2.8 m/s. It encounters a rough region where the coefficient of friction is µk = 0.7.
a) What is the shortest length of rough floor which will stop the box?
b) If instead the strip is only 0.28 m long, with what speed does the box leave the strip?
Relevant Equations:
Work Energy Theorem, Chane in Kinetic Energy = Work done on box.
I already found the answer to part a.)
(1/2)mv(final)^2 - (1/2)mv(initial)^2 = Ffriction
where i got: (1/2)(2.8)^2 = 0.7(9.81) * x
when i solved for x i got 0.571m
But its part b.) that I'm having the problem with. I set the problem up the same but solved for the velocity while i put in .28m for the distance
well energy is always conserved. Therefore: [tex]\frac{1}{2}mv_1^2 + F\Delta d = \frac{1}{2}mv_2^2 + F\Delta d[/tex]
So you know that Friction is playing no part in the initial velocity so you can get rid of Fd from the LHS.
You cancel the masses, you have initial velocity, distance and the retarding force of friction. Solve for v2
That's exactly it. I got the right answer. I was setting it up like this:
(1/2)mv(final)^2 - (1/2)mv(initial)^2 = Ffriction over the distance.
My problem with this set up was i wasn't making the friction negative. That's why i was getting the wrong answer.
Thanks so much for your help!
I'm still stuck on this problem... Using this equation: (1/2)mvf^2-(1/2)mvi^2= (F*d) or coefficient of friction*mgd
So my final equation to solve for vf is:
vf= (squareroot): 2(coefficient of friction*gd+vi^2)
But my answer is still wrong. Could someone please help me? It must be the numbers I'm plugging into the equation.
Here are the number given:
(b)If instead the strip is only 0.17 m long, with what speed does the box leave the strip?
I found that the shortest length of rough floor which will stop the box is 0.57m in part (a)
So, we know that energy is going to be conserved. First I'd write out a balanced equation using all the types of energy we have in this question:
[tex]\frac{1}{2}mv_1^2 + F_1\Delta d_1 = \frac{1}{2}mv_2^2 + F_2\Delta d_2[/tex]
because there is no initial friction, we can get rid of the [tex]+ F\Delta d[/tex] on the left hand side, or get rid of the one on the right hand side and make the one on the left hand side negative (both yield the same answer mathematically).
solve for v2
10K
