How does gravitational field exert gravitational force on a body?
adjurovich
34
I am not sure if there is in fact a classical description of how it occurs, but I’d like to know if there isn’t too!
In Newtonian mechanics, there is no "gravitational field". In general relativity, there is no "gravitational force".
  • Skeptical
Likes Vanadium 50, weirdoguy, pines-demon and 1 other person
I am not sure about that, we can define the Newtonian gravitational field ##\mathbf F =m \mathbf g(r)##, where ##\mathbf F## is the force due to gravity on a mass ##m## and ##\mathbf g(\mathbf r)## the gravitational field.
Newton's law can even be made into a Gauss' law of gravity: ##\nabla\cdot \mathbf g=-4\pi G \rho(\mathbf r)## (together with ##\nabla \times \mathbf g = 0##).
Likes russ_watters, dlgoff, adjurovich and 1 other person
What do you use this equation for, then?
##g = \dfrac{F}{m}##
There is also gravitational field in classical mechanics, but Newton never truly understood gravity… but do we?
There is a gravitational field in Newtonian's mechanics. However this field is instantaneous and that already bothered Newton and many people after him.
There were mechanical explanations of gravity but none was very useful (aether theories were not any better either). The only one that became almost challenging was Le Sage's gravitational theory but even that violates thermodynamics. So I guess the best was just to keep Newton's law of gravitation as an axiom. There is a field and that fields pulls masses together. Period.
Likes hmmm27
I disagree. In Newtonian mechanics you certainly can define a gravitational field. It just doesn't have any interesting dynamics on its own.
Likes cianfa72, adjurovich and pines-demon
Since in our best theory of gravity the gravitational field does not exert a gravitational force, what does the question in the title of the thread refer to?
I have asked about classical (more precisely Newtonian) description, not the relativistic one. You cannot expect from a high school student to know much about general theory of relativity?
Likes Dale and PeroK
I see. Anyway, the modern answer to that question is, it does not. Here is "the answer" from Gravitation by Misner, Thorne, and Wheeler:
This is essentially the same question as in your last thread, with "gravity" swapped for "electric".
If you read both questions you can clearly see that they are referring to two totally different things. But since you seem to be very much interested into my posts, I won’t be explaining anything further. If you have nothing else to do than compare and analyze questions of a high school student, I highly suggest you to find a hobby. There is always an option to skip a question you don’t like? It’s better than spamming someone’s inbox and wasting your own precious time on writing useless replies
  • Sad
Likes PeroK
He didn't spam your inbox. More likely you got a notification that he replied in your thread. Please be careful using the term "spamming" here. Thank you.
Likes Vanadium 50 and dlgoff
That would be the second paragraph in post #5, to which you've yet to respond.
Likes pines-demon
As others have mentioned, there are two major theories of gravity: Newtonian gravity and general relativity.
In Newtonian gravity, there is not a cause-and-effect relationship. Causes come before effects, and that doesn't happen in Newtonian gravity. A change in the sources occurs at the same time as a change in the field, not before. Furthermore, the field has no internal dynamics. So, while mass is the source of gravity, the relationship is not a causal one, which is weird.
In general relativity, there can be a cause-and-effect relationship in many cases. The field has interesting internal dynamics. The source of gravity is not just mass, but the full stress-energy tensor which includes mass, energy, momentum, pressure, and stress. The field is not a force field but represents the tidal effects of gravity. In the cases with cause-and-effect changes in the stress-energy tensor cause changes in the field, changes propagate at ##c##, and those cases include many realistic scenarios.
Likes cianfa72, nasu, adjurovich and 1 other person
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
