How does hoarfrost form in the morning?
  • Thread starter Thread starter Reason
Hoarfrost forms in the morning when water vapor in the air sublimates directly into ice at temperatures below freezing. This phenomenon occurs despite atmospheric pressure because the air can become supersaturated with moisture, allowing sublimation to happen. The process may involve a combination of sublimation and condensation, where water vapor transitions to ice without becoming liquid. The dew point near surfaces like leaves can drop, facilitating the formation of hoarfrost. Understanding these mechanisms highlights the complex interactions between temperature, pressure, and humidity in atmospheric conditions.
Reason
I was wondering how it comes that we have hoarfrost in the morning. Water has his tripplepoint at 0.001°C and 10³Pa, so subblimation occurs at lower pressure and temperature. But we have atmospherical pressure of 10^5Pa, so how comes we have hoarfrost?
http://www.lsbu.ac.uk/water/phase.html
I think it has something to do with partial pressure (Law of Dalton), but I'm not sure how...
I could be wrong about the technicalities, but when I have seen hoarfrost(an otherwordly, beautiful site, eh?)on trees, shrubbery, fences, etc... I was under the impression that the primary mechanism involved(other than freezing temps)was supersaturated air.
Any insight?
So no one knows why water sublimates at this pressure?
Is hoarfrost formed by (reverse) sublimation? Maybe it's only a special kind of condensation, folowed by freezing? What is the dewpoint right next to the leaves or whatever where the hoarfrost forms?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
