How Does Induced EMF Affect the Polarity of a Spinning Bicycle Wheel?
Induced electromotive force (EMF) occurs across the spokes of a spinning bicycle wheel due to the interaction with Earth's magnetic field, which is horizontal and perpendicular to the wheel's plane. The polarity of the hub and rim can be determined using Faraday's law, which states that a change in magnetic flux induces a current. Lenz's law indicates that the induced EMF will oppose the change in magnetic flux, providing insight into the direction of the induced current. The discussion emphasizes the need to apply the right-hand rule to ascertain the direction of motion and the resulting EMF. Understanding these principles is crucial for solving the problem effectively.
ehabmozart
A student is experimenting with a bicycle wheel. He turns the bicycle upside down and spins the wheel in a vertical plane at a constant rate. The diagram shows the wheel. At the place where the experiment is performed, the Earth‟s magnetic field is in a horizontal direction. It acts into and perpendicular to the paper.
A constant e.m.f. is induced across the length of each spoke.
(i) Label the hub and rim either plus or minus to show the polarity of the e.m.f.
The figure shows a wheel with the direction of motion clockwise. The hub is the center and the rim are the outerpart
Lenz's Law
Well, in this problem, it is said that the magnetic field lines point inside the paper. So if this is cut, it tries to oppose it... Hence, magnetic field lines should be outside. We should use flemings right hand rule but i have no idea about what would be the new direction of the spokes of the wheel (i.e the motion) and indeed upon that i don't know the direction of E.M.F... I need help urgently.. Thanks!
Guys! I urgently need help. Thanks!
People Here! This is one important question... Please help whoever can contribute with a good reply... I will owe him/her big time!
You didn't post the diagram.
Lentz's law isn't the appropriate one. You need to use Faradays law: "change in magnetic flux induces a current"(tries to oppose the change in magnetic flux according to lenz law)
So it induces an EMF which should result in an opposing magnetic flux.
So Lenz's law only gives a hint of the direction.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
