How Does Ion Momentum Relate to Magnetic Fields and Circular Motion?
  • Thread starter Thread starter Drevin
    Electromagnetism
An ion with a charge of 1.6*10^-19 enters a 0.075 T magnetic field and follows a circular path with a radius of 0.083 m, leading to a calculated momentum of 9.96 * 10^-22 kgm/s using the formula Momentum = QBr. The original poster faced confusion as their answer did not match the provided multiple-choice options. Discussion revealed that the discrepancy was due to significant figures, as the answer should have been rounded to two significant figures. Ultimately, it was clarified that the calculated momentum was close to one of the choices, and proper rounding would yield a match. The conversation emphasized the importance of significant figures in physics calculations.
Drevin
An ion with a change of 1.6*10^-19 enters a 0.075 T magnetic field. If the ion follows a circular path of radius 0.083m, what is the momentum of the ion?
I tried manipulating Fc = Fmagnet into Momentum = QBr, but that didn't work... any ideas?
Thanks!
What do you mean it didn't work?
Well, it's a multiple choice question, and the answer I got wasn't any of them.
F = qvB
You obviously know this. But what must the magnetic force do to keep the charge moving in a circle?
Write down the complete equation and the subsequent steps as you would have, for your homework. What you've written above is not an equation.
Your solution, "Momentum = QBr", is certainly correct. What were the other choices? If the choices were numerical, perhaps you made an arithmetic error.
The choices are:
A) 2.7 * 10^-26 kgm/s
B) 1.0 * 10^-21 kgm/s
C) 1.7 * 10^-12 kgm/s
D) 5.2 * 10^-4 kgm/s
The answer I got was 9.96 * 10^-22 using Momentum = QBR
mv = QBr
P = (1.6*10^-19)(0.075)(0.083)
P = 9.96 * 10^-22
That's what I did.
Drevin said:
The choices are:
mv = QBr
P = 9.96 * 10^-22
That's what I did.
Your answer is correct, except it is written to 3 sig figs, when it should only be written to 2. Do this, and you'll find that one the the given choices is correct.
I misunderstood what you'd written in the OP in my earlier post. After re-reading, it is clear what you did. My bad, sorry.
significant figures
Drevin said:
The choices are:
mv = QBr
P = 9.96 * 10^-22
You should realize that your answer is extremely close to one of those choices, so close that if you had to choose (and you do!) there should be no question as to which one to pick. (The other choices are off by many orders of magnitude--they aren't even close!) And, as Gokul says, if you had worked out your answer to 2 significant figures--as you should have, given the data--you would have found a perfect match. (Since the data you were given only had two significant figures, your answer must have no more than two significant figures.)
Ah, yes.. you're correct! (Our class doesn't tend to use sig figs very often, so I think that's where I got confused)
Thanks so much for the help!
I'll write down my steps a little more clearly next time I post a question, too.
