How Does Light Refract Through Water and Crown Glass?
4 replies · 3K views · last reply
ryanvoy
A block of crown glass (refractive index - 1.52) is covered by a sheet of water (refractive index - 1.33). a ray of light incident on the water with a angle of incidence of 55 degrees. find the angle that this ray makes with the normal when it emerges from the glass...
PLEASE help, this is the only question i can't do...
thanks,
Regards Ryan Voy
ryanvoy@hotmail.com
HINT: Apply Snell's Law at each of the three interfaces.
thanks i knew i had to do that but I am getting a different answer to the textbook,
My answer - 32.61 degrees'
text books answer 69.4 degrees
sorry 4 the trouble
Thanks regards Ryan
ryanvoy@hotmail.com
The answer should be exactly 55 degrees, and you can do this without even invoking Snell's law explicitly. As long as the sides of all the interfaces are perfectly parallel, the exit ray in the same medium has to be parallel to the incident ray in that medium.
EDIT : This is assuming that the glass is covered on only one side with water and the final ray emerges into air.
