How does one do the following Integral.
  • Thread starter Thread starter Quantumpencil
    Integral
The discussion revolves around calculating the electric flux through a face of a cube due to a point charge located at the center. The original poster successfully used Gauss's law to find the flux as q/6ε but struggles with the integral approach, which they find complex. They detail their attempt to set up the integral in Cartesian coordinates but receive feedback emphasizing the unnecessary complexity of the integral since the flux has already been determined using Gauss's law. The consensus suggests that if one method yields a straightforward solution, it may be best to use that instead of pursuing a more complicated integral. Ultimately, the discussion highlights the balance between exploring different problem-solving methods and recognizing when a simpler solution suffices.
Quantumpencil
The problem is really not bad; It's to find the flux due to a point charge at the center of Cube of side length d. I've gotten the answer I believe using Gauss's law (q/6epsilon)
I tried doing a Flux integral, and the integral seems kind of a pain in the ***... I'm not sure how to do it. I will post where I'm at and hopefully someone can tell me how to integrate this.
the exact question was
"Find the flux through a face of a cube from a point charge at the cube's center"
First I chose the face, assuming the charge is at the origin, such that da=dzdy(x), x = d/2, and y and z vary from -d/2 to d/2. I then changed Coulombs law to Cartesian coordinates and did some dot products, and substituted in d/2 for x.
\int[\frac{Q(d/2)}{(d^2/4)+y^2+z^2)^{3/2}}dydz
How can one integrate this?
Please write down the question exactly as it was given to you. An electric field can not have dimensions of q/epsilon (a flux can). And please be more clear in your working - write full equations instead of fragments. Right now, one can only guess what you are trying to calculate.
Yeah, don't know why I typed Electric field, the problem is to find
\int(E)\cdot da, the flux through the surface.
If you already figured out the flux using Gauss' law and symmetry, why do you need to do the painful integral?
I mean, I just usually try to work problems multiple ways. If the integral isn't do-able then I suppose I won't, but often times I just don't think of the proper tricks to solve integrals and things, and doing problems that was as well keeps my bank of problem solving knowledge sharper.
I'm sure you probably can do it. But I think the lesson learned would be disproportionate to the effect involved. If it's easy both ways, do it both ways. If it MUCH easier one way stick with that one.
  • · Replies 19 ·
