- 3,641
- 10,062
Lsos said:Apparently you're not understanding it either, because as the rocket goes faster, the exhaust velocity with respect to the rocket does NOT go down. And that's the whole point of this discussion and the whole reason for all the confusion.
It's not something that makes sense unless you put some time to think about it, and/ or start a thread to get some help figuring it out.
I shouldn't have brought back the rocket. I don't know how to tell this simpler than it is:
P = Fv
F = ma
a = dv/dt
3 possible cases:
1- Object at constant velocity:
dv = 0; a = 0; F = 0 ---> P = 0
2- Object at constant acceleration:
F = constant; P/v = constant ----> P is proportional to v
3- Object at constant power (which I think is the subject under discussion):
Fv = constant ----> F is inversely proportional to v. Which leads to a is inversely proportional to v
If you have a rocket under constant power - same amount of energy spent on the rocket's motion in a given time - the thrust will be smaller as the speed of the rocket goes up, whether you decrease the velocity of the exhaust or its mass flow rate: something has to give.
Why is that? Because for the rocket that goes faster, the displacement will be greater in the same time dt. And since we assume that the energy spent will be the same and that energy = force times displacement, therefore the force must go down for the faster rocket to respect the initial assumption that power is constant.
And that is true for any type of object going through any type of motion.
Right now, you all have a problem similar to this https://www.physicsforums.com/showthread.php?t=408584", except that the person couldn't accept the first case (a constant v means zero power). And just like I said in that thread, I will give up at this point, as you are not even trying.
elicopter case is not complicating things, it is simplifying as it preserves mass of the system. Anyway I can modify my spaceship (not rocket) question: what if it would be propelled by light pressure of external laser shining with constant light (=constant power)? Would it accelarate at constant or decreasing pace? (Of course I assume idealistically void space , so no efficency loss of laser light with distance.)
