How Does the Definition of Arc Length Lead to Its Integral Formula?
The discussion revolves around the definition of arc length and its connection to the integral formula for calculating length along a curve. Participants are exploring the mathematical relationships involved in expressing arc length in terms of derivatives and integrals.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to connect the definition of arc length with its integral representation but expresses uncertainty about the steps involved. Some participants question the validity of certain equations and suggest clarifications regarding the relationships between differentials.
Participants are actively engaging with the problem, providing hints and corrections. There is a focus on understanding the correct expressions for derivatives and their implications for the integral formula. Some guidance has been offered regarding LaTeX formatting and mathematical notation.
There is a noted lack of clarity regarding the use of coordinates and the assumptions underlying the problem setup. The original poster also mentions difficulties with LaTeX formatting, which may affect the clarity of their expressions.
seanc12
Confirm that th definition of th arc length ds[tex]^{2}[/tex]=dr.dr leads to the formula
L=[tex]\int[/tex][tex]_{C}[/tex][tex]\frac{dr}{dt}[/tex]dt
[tex]\frac{dr}{dt}[/tex]=[tex]\frac{dx}{dt}[/tex]+[tex]\frac{dy}{dt}[/tex]+[tex]\frac{dz}{dt}[/tex]dt
I am really unsure of what to do here. I have tried starting at each of the given equations and trying to meet somewhere in the middle. I won't post all my working becauses most if it is gibberish and I am still trying to get this LaTeX thing to work properly for me. Can someone give me some hints in what I am trying to get here.
the best I've gotten is expanding the dot product to get
ds^2=dx^2+dy^2+dz^2
Since nothing at all is said about xyz-coordinates in the original problem, I don't see why you are changing to dx, dy, and dz.
(And certainly dr/dt= dx/dt+ dy/dt+ dz/dt is NOT true. What is true is that
[tex]\frac{dr}{dt}= \sqrt{\left(\frac{dx}{dt}\right)^2+ \left(\frac{dy}{dt}\right)^2+ \left(\frac{dz}{dt}\right)^2}[/tex])
From [itex]ds^2= dr\cdot\dr[/itex], take the square root of both sides.
Hi HallsofIvy, thanks for the reply.
Yes ofcourse, how could i have been so silly :P wasn't paying attention properly thanks for pointing that out.
[tex] \frac{dr}{dt}= \sqrt{\left(\frac{dx}{dt}\right)^2+ \left(\frac{dy}{dt}\right)^2+ \left(\frac{dz}{dt}\right)^2}[/tex]
I understand the RHS, but howcome it is = to dr/dt instead of ds/dt?
Also as a note, the C on the integral should be a subscript but it doesn't seem to want to go there
You need to put the entire expression in one set of tex tags, e.g. [tex]\int_a^b dx[/tex] gives:
That's the magnitude of [itex]dr/dt[/itex] in terms of dx,dy,and dz.
[tex]\int_C \frac{d <u>r</u>}{dt}dt[/tex]
Thanks,
So from there can i go ahead and substitute the [tex]\frac{d <u>r</u>}{dt}[/tex] back into the integral? or am i missing a few steps? It seems a little easy. Also, where does the C come into it?
Also, howcome the underlines don't show up in my LaTeX?
