How does the number of turns in a loop affect the torque in a magnetic field?
The discussion focuses on how the number of turns in a wire loop affects the torque experienced in a magnetic field. The original poster calculated torque from both the hanging mass and the magnetic field but initially overlooked incorporating the number of turns. It was clarified that for multiple turns, the torque can be expressed as T = NIA x B, where N is the number of turns. The conversation emphasizes the importance of including the number of turns in torque calculations, as it directly increases the torque produced by the loop in a magnetic field. Understanding this relationship is crucial for solving related physics problems effectively.
estanton
The 10-turn loop of wire shown in the figure lies in a horizontal plane, parallel to a uniform horizontal magnetic field, and carries a 2.0A current. The loop is free to rotate about a nonmagnetic axle through the center. A 50g mass hangs from one edge of the loop.
Torque = r x F
Torque = IA x B
My thought was to simply calculate the torque created by the mass and then relate that with an opposite torque provided by the magnetic field. I suspect that I'm calculating the torque created by the hanging mass wrong, since I haven't really dealt with torques in some time.
Torque = r x F -> .025m*.05kg*9.8m/s^2 = .01225 Nm
Torque = IA x B -> Torque/IA = B -> .01225/(2.0A*(.05*.1)) = B = 1.225 T
If someone could help with what I'm overlooking here I would appreciate it.
never mind, I figured out that I have to use N (number of turns) in with mu.
Hey, I tried the same thing you did... how do you factor in the number of turns?
Welcome to PF :smile:
For a 1-turn loop, the torque is what estanton had before:
T = I AxB​
If instead you have 10 loops, can you tell how that affects the torque?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
