How Does Thermal Energy Compare to Ionization Energy in a Flame?
  • Thread starter Thread starter physicsnobrain
    Energies Ionization
The discussion revolves around comparing thermal energy and ionization energy in the context of lithium in a flame, specifically examining whether significant ionization occurs at a given temperature. Participants explore the implications of thermal energy approximated by the Boltzmann distribution and the specific ionization energies of lithium.
  • Homework-related
  • One participant approximates thermal energy in the flame as RT and questions whether significant ionization of lithium occurs at high temperatures.
  • Another participant challenges the concept of "ionization energy of the flame," seeking clarification on its relevance to the problem.
  • A participant asserts that lithium is not significantly ionized, but does not provide a basis for this claim.
  • Further, a participant requests calculations to support claims regarding ionization.
  • One participant argues that the thermal energy (RT) is much less than 4RT, suggesting this indicates low ionization potential.
  • Another participant counters that the energy distribution must be considered, emphasizing that thermal energy is not a fixed value and questions the comparison to ionization energy.
Participants express disagreement regarding the significance of lithium's ionization in the flame. Some assert it is not significantly ionized, while others seek clarification and calculations to support or refute this claim. The discussion remains unresolved.
Participants have not provided detailed calculations or a clear basis for their claims, leading to uncertainty in the discussion. The implications of the energy distribution and its relation to ionization energy are not fully explored.
physicsnobrain
The energy of particles in a flame at a temperature T might be described by a
Boltzmann distribution. Temperature can be converted to energy (and thereby velocity)
using the gas constant R = 8.3145 J mol-1 K-1. Let us approximate thermal energy in the
flame by RT (squiggly lines mean approximately) where T is in degree Kelvin:
thermal energy ≈ RT
The first ionization energy for Li is 5.20 x 10 2 kJ/mol and the second ionization energy
is 7.29 x 103 kJ/mol. Assume that your Bunsen burner reached 869 ºC, and that nearly all
of Li atoms heated in your Bunsen burner had energies less than 4 x RT. Would you or
would you not expect significant ionization in the flame? Explain.
The ionization energy for Li is the opposite of the ionization energy of the flame. The second Li ionization is fairly high, and as a result, I would expect that the ionization energy of the flame is not very significant because the Li ionization is high. Lithium is high on the list of reactive elements, they increase in reactivity going down, example, francium is much more reactive than lithium, I would expect a much larger ionization of flame from franciums ionization compared to lithium.
Am I correct?
What does "ionization energy of the flame" mean?
I don't understand what this has to do with the problem. You only have to consider lithium in the flame. Is it significantly ionized or not?
no it is not significantly ionized. I said that.
But based on what? I would like to see some calculations...
well obviously R x T is wayyyyyyyyy less than 4(R)(T)
That is why
You're comparing ##RT## with ##4RT##? I think you misunderstood the statement of the problem. First, it says that ##E_\mathrm{thermal} \approx RT##, then that ##E_\mathrm{thermal}## is at most ##4RT## (the energy follows a distribution, it is not a fixed value). So how does that compare to the ionization energy?
61K
18K
10K
93K
  • · Replies 18 ·
