How Does Vertical Distance y(t) Satisfy the Given Differential Equation?
  • Thread starter Thread starter kaitlync
    Calc 3 Roller
kaitlync
2. If y(t) is the vertical distance traveled at time t, then the same reasoning as used in Problem 1shows that v2= (2gy)/(1+I*) at any time. Use this result to show that y satisfies the differential equation
dy/dt=sqrt(2g/(1+I*))*(sin alpha)*sqrt(y)
where a is the angle of inclination of the plane.
I plugged dy/dt into v, because is the derivative of position. I have dy/dt=sqrt(2g/(1+I*))*sqrt(y) because you can pull it out, but i don't know how to get the sin alpha
It would have been better to include problem "1" rather than expecting people to gues what the problem really is.
It looks like you have an object moving on an inclined plane and y is the vertical height. But what is I*?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
