Loren Booda
- 3,108
- 4
What single observable (such as complexity) might characterize Earth as unlike any other planet in the universe?
And some reason to suspect that all of them are unique in some way. We have a very small sample to observe here in our neighborhood, and there are some vast differences between them in many metrics. There is no reason to assume that other planetary systems would not have significant differences, as well. We have discovered extra-solar planets by lots of means, not the least of which is tracking light-curves to discover large planets partially occulting their stars when their orbits are aligned with our line-of-sight. Are we going to find a "Mercury" orbiting a large star that way? Probably not for a very long time.Xnn said:There's roughly 10^24 planets in the universe.
No reason to suspect that ours is unique.
Andre said:The large moon, stabilizing it's spin axis, preventing Earth from getting into the chaotic zone
Earth has both cyrus and evo - that must be pretty unique!Loren Booda said:What single observable (such as complexity) might characterize Earth as unlike any other planet in the universe?
Loren Booda said:Might such a large moon - having its genesis in the coalescing debris of a planetary impact - be more likely suited to avoid chaos by stabilizing the spin axis of the resultant planet?
Read section 2.2 of the paper that Andre cited. It is Earth's obliquity rather than its orbit that the Moon acts to stabilize. Lasker is claiming that Venus' rather anomalous rotation is due solely to gravitational effects by the other planets. The Moon acts to stabilize the Earth's rotation.Integral said:I am not sure what the deal is with the moon and stability? We have moonless Venus and Mercury, clearly a moon is not a necessary thing.
Andre said:But are Venus and Mercury anywhere near Earthlike? The only thing that Venus shares with Earth is the order of magnitude of its size
That was pithy.negitron said:No, it's not.Andre said:But it is the subject of the thread.
D H said:That was pithy.
The subject of this thread is the uniqueness of the Earth. Loren asked
I agree that that is the hidden agenda behind his original post. That is not what Loren asked in the original post. What Loren asked was "What single observable (such as complexity) might characterize Earth as unlike any other planet in the universe?"SW VandeCarr said:The subject here is really whether there are any other planets having characteristics friendly to intelligent life as we know it.
D H said:The end result is the same: We are alone. The only way we are not alone is if there are hundreds of billions of Earth-like planets spread around the universe.
That's a better question, but you are still eliminating a lot of explanations for why some say the Earth is rare. The word "physics" pretty much eliminates geological, chemical, and biological concerns (assuming you don't consider geology, chemistry, and biology to be branches of physics). The words "Earth's physics" pretty much eliminates attributes of the parent star and perturbing effects by other planets in the star system.Loren Booda said:How might Earth's physics be most unlike that of any practically observable planet?
What does this number mean? That one out of every 10 billion stars has an Earth-like planet?Xnn said:By that definition, Earth is probably 1 in a 10 billion.
You are once again stating highly hypothetical things as if they are fact. This is not the site for doing that.However, consider that the visible Universe is not the only Universe in existence. Instead, it is just a single Universe of the greater Multiverse.
But the dynamic role of the gravity of considerable moon on the Earth physics is worth mentioning.
http://en.wikipedia.org/wiki/Tidal_accelerationThere is geological and paleontological evidence that the Earth rotated faster and that the Moon was closer to the Earth in the remote past.
Ophiolite said:Plate tectonics. ... or a periodic catastrophic affair as on Venus.
AFAIK, the tides are not the mechanism by which the Moon aids in keeping the Earth's rotation stable. Tides are dissipative forces. The same gravity gradient forces that cause the tides also induce a conservative torque on the Earth as a whole. This torque, averaged out over the Moon's 18.6 year nodical period, results in the 26,000 year lunisolar precession.Richard111 said:Ooops, yes. Solar tides. But would that have been sufficient to maintain spin stabilisation? Would the limited range of solar tides have encouraged life to adapt to less exposed land surfaces?
Emphasis mine. This is purely conjectural.Richard111 said:Without the moon, life as we know it may not have been possible.
I am not debating that the Moon slows the Earth's rotation rate. That is a fact. What is debatable is whether the Earth's day would be eight hours long if the Moon never existed. If indeed the Moon formed from a collision between the Earth and Theia, we do not know how much the collision itself changed the Earth's rotation rate.Richard111 said:wikipedia said:There is geological and paleontological evidence that the Earth rotated faster and that the Moon was closer to the Earth in the remote past.
Ophiolite said:There are two principal options:
1. The resurfacing event that occurred around 600 million years ago and the stagnant lid period that preceded it, were themselves preceded by 'conventional' plate tectonics.
2. The resurfacing event etc, was the most recent in a series of such events.
You have to dispose of the internal heat. These are the two obvious mechanisms. I have a gut feel - unquantified - that continuous conventional plate tectonics should have maintained water content on the planet, so I lean to the possibility of periodic resurfacing. The evidence is consisten with either.
There are no assumptions here, only reasonable deductions leading to plausible hypotheses.Andre said:but these are still suppositions following assumptions about heat and heat production in the core, which are also hypotheses.
