How fillers are added to silicon fluids?
  • Thread starter Thread starter amrmohammed
    Fluids Silicon
5 replies · 2K views
amrmohammed
Some silicon products (like silicon greases) have different types of fillers added to it (like silica and carbon black) to give it certain properties. How these fillers are added/combined/"dissolved" to the silicon fluid?
Liquids are mixed with liquids, powders are often ground in, a process called mulling.
wouldn't the powder settle down after a period of time if it were just mixed with the silicone? are there some kind of minimum shear power to fully mix the components to one mixture, or can I do it at home like mixing water and salts?
It depends on what kind of silicon polymer you have. Usually they are gels or thick fluids which will hold onto suspensions. If it is a fluid it is a complicated but not too difficult subject. It depends on such things as the polarities of what you are adding and whether they are attracted to the silicon - but on several other factors as well. With paint for example there are modified oils that mix with water, furthermore there are intermediary chemicals (I forget the name) which will bind on to the pigment with one end of the molecule and to the oils with the other. Do look up mulling btw!
Thank you Puma
I tried searching "mulling" and "silicone mulling" but the results were not related to the topic. Are you sure of the spelling?
Yes its right! You'll have to look up mulling paint I guess to get good info. But anyhow basically all you need to know is that powders have to be really finely ground into the carrying medium to disperse it evenly eg by hand with paint this equates to a flat stone, oil, pigment and another flat stone. Sorry to make a meal of this simple process!
