How in the blazes is this the derivative of f(x)?
  • Thread starter Thread starter neutron star
    Derivative
neutron star
f(x)=(2x+1)^11 (5x-1)^9
f'(x)=[(2x+1)^10 (5x-1)^8] * (200x+23)
Where does the +23 come from, I don't get it. I get the rest.
Your function and it's derivative are difficult to comprehend, as you have an error in your LaTeX.
I believe this is what you meant:
f(x)=(2x+1)^{11} (5x-1)^9
f'(x)=[(2x+1)^{10} (5x-1)^8] * (200x+23)
If you have an exponent that consists of more than one character, you have to put braces, {}, around it.
Using the product rule, f'(x) = 11*2*(2x + 1)10*(5x - 1)9 + (2x + 1)11*9*5*(5x - 1)8
= 22*(2x + 1)10*(5x - 1)9 + 45*(2x + 1)11*(5x - 1)8
= (2x + 1)10*(5x - 1)8[22(5x - 1) + 45(2x + 1)]
= (2x + 1)10*(5x - 1)8[110x - 22 + 90x + 45]
= (2x + 1)10*(5x - 1)8[200x + 23]
EDIT: Way too late. Disregard this, Mark44 beat me to it.
You use the product rule to get:
f'(x) = (5x-1)^9\frac{d}{dx}(2x+1)^{11} + (2x+1)^{11} \frac{d}{dx}(5x-1)^9
Use the chain-rule to calculate these two derivatives. Then with a little bit of rearranging you should get the desired result. As to where the 23 comes from it occurs naturally when you do the calculation, or a bit more concretely:
(5x-1)11(2) + (2x+1)9(5) = 110x+90x+45-22 = 200x+23
which you shall find when you do the calculations.
I don't see how you can get the rest of the answer unless you made a mistake. Try showing how you got the rest, but not the +23.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
