How is the following derived: Please help derive the following: dPh/dR
  • Thread starter Thread starter Zashmar
    Derive
The discussion focuses on deriving the power transfer equation in a series circuit involving internal resistance (Ro) and heater resistance (Rh). The power across the heater, Ph, is expressed as Ph = V^2Rh/(Ro + Rh)^2, where V is the constant voltage. To maximize power transfer, the derivative dPh/dRh is calculated, leading to the condition that Rh must equal Ro for maximum efficiency. This result underscores the principle that optimal power transfer occurs when the load resistance matches the source's internal resistance. The conversation emphasizes the importance of understanding these relationships in circuit design.
Zashmar
Here is the working leading up to this:
The circuit is a series circuit, with Ro being the circuit's internal resistance and Rh being the heater's resistance. We're only concerned about the power transfer to Rh. We have an input with a constant voltage V. Ohm's law: V = IR, where R is the total resistance of the circuit. In a series circuit this total resistance is the sum of the resistances in the circuit.
I = V / (Ro + Rh)
The voltage developed across the heating resistance will again be dictated by ohm's law:
Vh = I * Rh
Substitute: Vh = V * Rh / (Ro + Rh) P = I Vh
so Ph = [V / (Ro + Rh)] * [V * Rh / (Ro + Rh)]
Ph = V2 Rh / (Ro + Rh)2
Rh is the only variable, since Ro and V are fixed in this context. In order to find the maximum power transfer, we optimize this equation. Optimization theorem: a functions optimum points occur at the function boundaries, and where the first derivative of the function is equal to zero. In this case we're not going to look at the boundaries, since they are at 0 and infinite.
dPh/dRh = V2 (Ro - Rh) / (Ro + Rh)3.
What do you men on V2 and (Ro + Rh)2 ? Do those "2"-s mean square? Then use ^ as V^2 or (Ro+Rh)^2 or
click to "Go Advanced" and you can find above the text the symbols X2 and X2, so you can write the square of something as something 2.
So: I=V/(Ro+Rh)
and
Ph=V2Rh/(Ro+Rh)2.
It is even better to use TeX
I=\frac{V}{R_0+R_h}
P_h=I^2R_h= \frac{V^2R_h}{(R_0+R_h)^2}
You get the derivative of Ph with respect to Rh with the formula for the derivative of a fraction, and simplifying. If F(x) = g(x)/h(x) F'=\frac{g'h-gh'}{h^2}
So
\frac{d P_h}{dR_h}=V^2\left(\frac{(R_0+R_h)^2-2R_h(R_0+Rh)}{(R_0+R_h)^4}\right)
Simplify.
ehild
I am a high school student, how would i simplify that, and in terms of maximum efficiency of a wire what does this mean? ie in terms of matching impedance
The power on Rh is maximum if its derivative dPh/dRh is zero. The derivative is shown in my previous post, but it can be simplified if you factorize the numerator. \frac{d P_h}{dR_h}=V^2\left(\frac{(R_0+R_h)^2-2R_h(R_0+Rh)}{(R_0+R_h)^4}\right)=V^2\left(\frac{(R_0+R_h)(r_0+R_h-2R_h)}{(R_0+R_h)^4}\right)=V^2\frac{r_0-R_h}{(R_0+R_h)^3}=0
What should be Rh to make the expression equal to zero?
ehild
So Rh has to equal Ro? wow thanks man
Yes, it is. You get the maximum power out of a voltage source on a load, equal to the internal resistance of the source.
ehild
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
