How is the Maxwell-Boltzmann Distribution Derived?
The Maxwell-Boltzmann distribution is derived through the partition function, represented as ##z=\frac{Vm^3}{h^3}\int d^3 \vec{v}e^{-\beta \frac{mv^2}{2}}##. The integration involves converting to spherical coordinates and ensuring the correct application of the normalization constant ##A##, which is calculated as ##A=4\pi \left( \frac{m}{2\pi k_BT} \right)^\frac{3}{2}##. Key corrections noted in the discussion include the necessity of a volume term ##V## and a minus sign in the exponential function. The discussion emphasizes the importance of accurate notation and integration techniques in deriving the distribution.
  • Understanding of classical mechanics and thermodynamics
  • Familiarity with statistical mechanics concepts
  • Proficiency in calculus, particularly integration techniques
  • Knowledge of LaTeX for formatting equations
  • Study the derivation of the canonical partition function in statistical mechanics
  • Learn about spherical coordinates and their application in multi-dimensional integrals
  • Explore the implications of the Maxwell-Boltzmann distribution in real-world systems
  • Review normalization techniques for probability distributions in statistical physics
Students and researchers in physics, particularly those focusing on statistical mechanics, thermodynamics, and kinetic theory. This discussion is beneficial for anyone looking to deepen their understanding of the Maxwell-Boltzmann distribution and its derivation.
Heisenberg2001
Consider a monoatomic gas, whose momentum relation is ##\vec{p}=m\vec{v}##, where ##\vec{v}## is the three-dimensional velocity of the gas particles.
1. Show that the classical partition function can be written as $$z=\frac{4\pi m^3}{h^3}\int dv v^2e^{\beta \frac{mv^2}{2}}.$$
2. Let ##f(v)=Av^2e^{\beta \frac{mv^2}{2}}.## Find ##A## such that ##\int_{0}^{\infty}dv f(v)=1.##
##\vec{p}=m\vec{v}\, , \,z=\frac{4\pi m^3}{h^3}\int dv v^2e^{\beta \frac{mv^2}{2}}##
##f(v)=Av^2e^{\beta \frac{mv^2}{2}}\, , \,\int_{0}^{\infty}dv f(v)=1##
1.
##H=\frac{\vec{p}^2}{2m}+V=\frac{1}{2}m\vec{v}^2##
##z=\frac{1}{(2\pi \hbar)^3}\int d^3\vec{q}d^3\vec{p}e^{-\beta H(\vec{p},\vec{q})}##
##z=\frac{Vm^3}{(2\pi \hbar)^3}\int d^3 \vec{v}e^{-\beta \frac{mv^2}{2}}##
##z=\frac{Vm^3}{(2\pi \frac{h}{2\pi})^3}\int d^3 \vec{v}e^{-\beta \frac{mv^2}{2}}##
I am lost at this point of the solution. Can someone assist me with this?
2.
##\int_{0}^{\infty}dv f(v)=1##
##\int_{0}^{\infty}Av^2e^{\beta \frac{mv^2}{2}}dv=1##
##A\int_{0}^{\infty}v^2e^{\beta \frac{mv^2}{2}}dv=1##
##A\frac{1}{4\left(\frac{\beta m}{2} \right)}\sqrt{\frac{\pi}{\frac{\beta m}{2}}}=1##
##A=\sqrt{\frac{4\beta ^3m^3}{2\pi}}##
##A=4\pi \sqrt {\left(\frac{\beta m}{2\pi} \right)^3}##
Change to spherical coordinates and integrate the angles out.
There would still be a minus sign left in the exponential and a volume term V outside.
It appears ##z## is the contribution from just one particle to the partition function, and there should be a factor of ##V##. Also, the exponential should have a minus sign. It could simply be typos by the OP.
Yes, ##z## should be the contribution from one particle only as the integral is over a 6d phase space.
Also note that a - is missing in the exponential ;-).
How do I edit the equations that I have typed? I can't see an edit button.
After a short period of time, posts cannot be edited. Paste your latex into a fresh new post, then edit it to make your changes. Or add comments....
  • · Replies 19 ·
