How is the Maxwell-Boltzmann Distribution Derived?
The discussion revolves around the derivation of the Maxwell-Boltzmann distribution, focusing on the mathematical expressions and integrals involved in the process. Participants are examining the partition function and its components in the context of statistical mechanics.
  • Mathematical reasoning, Assumption checking
  • Participants are attempting to derive the partition function and are questioning specific steps in the integration process, particularly regarding the treatment of variables and the presence of signs in the exponential terms. Some are suggesting changes to spherical coordinates to simplify the integration.
The discussion is ongoing, with participants expressing confusion about certain steps and seeking clarification. There are indications of potential typos in the original post, and some participants are providing guidance on how to correct or clarify the equations presented.
There are mentions of specific constraints related to the editing of posts and the need to present equations clearly, which may affect how participants communicate their thoughts and corrections.
Heisenberg2001
Consider a monoatomic gas, whose momentum relation is ##\vec{p}=m\vec{v}##, where ##\vec{v}## is the three-dimensional velocity of the gas particles.
1. Show that the classical partition function can be written as $$z=\frac{4\pi m^3}{h^3}\int dv v^2e^{\beta \frac{mv^2}{2}}.$$
2. Let ##f(v)=Av^2e^{\beta \frac{mv^2}{2}}.## Find ##A## such that ##\int_{0}^{\infty}dv f(v)=1.##
##\vec{p}=m\vec{v}\, , \,z=\frac{4\pi m^3}{h^3}\int dv v^2e^{\beta \frac{mv^2}{2}}##
##f(v)=Av^2e^{\beta \frac{mv^2}{2}}\, , \,\int_{0}^{\infty}dv f(v)=1##
1.
##H=\frac{\vec{p}^2}{2m}+V=\frac{1}{2}m\vec{v}^2##
##z=\frac{1}{(2\pi \hbar)^3}\int d^3\vec{q}d^3\vec{p}e^{-\beta H(\vec{p},\vec{q})}##
##z=\frac{Vm^3}{(2\pi \hbar)^3}\int d^3 \vec{v}e^{-\beta \frac{mv^2}{2}}##
##z=\frac{Vm^3}{(2\pi \frac{h}{2\pi})^3}\int d^3 \vec{v}e^{-\beta \frac{mv^2}{2}}##
##z=\frac{Vm^3}{h^3}\int d^3 \vec{v}e^{-\beta \frac{mv^2}{2}}##
I am lost at this point of the solution. Can someone assist me with this?
2.
##\int_{0}^{\infty}dv f(v)=1##
##\int_{0}^{\infty}Av^2e^{\beta \frac{mv^2}{2}}dv=1##
##A\int_{0}^{\infty}v^2e^{\beta \frac{mv^2}{2}}dv=1##
##A\frac{1}{4\left(\frac{\beta m}{2} \right)}\sqrt{\frac{\pi}{\frac{\beta m}{2}}}=1##
##A=\sqrt{\frac{4\beta ^3m^3}{2\pi}}##
##A=4\pi \sqrt {\left(\frac{\beta m}{2\pi} \right)^3}##
##A=4\pi \left( \frac{m}{2\pi k_BT} \right)^\frac{3}{2}##
Change to spherical coordinates and integrate the angles out.
There would still be a minus sign left in the exponential and a volume term V outside.
It appears ##z## is the contribution from just one particle to the partition function, and there should be a factor of ##V##. Also, the exponential should have a minus sign. It could simply be typos by the OP.
Yes, ##z## should be the contribution from one particle only as the integral is over a 6d phase space.
Also note that a - is missing in the exponential ;-).
How do I edit the equations that I have typed? I can't see an edit button.
After a short period of time, posts cannot be edited. Paste your latex into a fresh new post, then edit it to make your changes. Or add comments....
  • · Replies 19 ·
