How Long Does It Take for the Block to Reach the Other Side?
A small block of mass 1.74 kg is set in motion on top of a larger block of mass 7.95 kg, with a constant horizontal force of 11.4 N applied. The kinetic friction between the blocks is calculated, leading to a net force on the top block of 6.64 N and an acceleration of 3.8175 m/s². Initially, the time calculated for the top block to reach the end of the lower block was 1.264 seconds, but this did not account for the motion of the lower block. After correcting for the distance the lower block travels, the correct time for the top block to reach the right side is determined to be 1.3766 seconds. The discussion highlights the importance of considering both blocks' movements in solving the problem.
rmb16
A small block of mass 1.74 kg rests on the left edge of a block of length 3.05 m and mass 7.95 kg. The coefficient of kinetic friction between the two blocks is 0.279, and the surface on which the 7.95 kg block rests is frictionless. A constant horizontal force of magnitude 11.4 N is applied to the 1.74 kg block, setting it in motion.
How long will it take before this block reaches the right side of the 7.95 kg block? The acceleration of gravity is 9.8 m/s2 . (Note that both blocks are set in motion when ~ F is applied. Answer in units of s.
Ffk=Uk(FN)
X=(1/2)at^2
F=ma[/B]
so to find the normal force (FN) that mass 1.74 exerts on the block below it I did 1.74kg*9.8m/s^2 to get a normal force of 17.052N. I then found the kinetic friction by multiplying the normal force by the coefficient of kinetic friction: 17.052N*.279=4.757N. I then found the net force exerted on the top block to be 11.4N-4.757N= 6.64N. so using F=ma I used the numbers: 6.64N=1.74kg*(a) and solved for a to be a=3.8175m/s^2. Then I used X=(1/2)a(t^2): 3.05m=(1/2)(3.8175)(t^2) and got t=1.264s. However, this time is apparently not correct and I am confused as to what I am doing wrong. Do I need to take into account that the bottom block is moving aswell?
That would be a good idea. You have found the time it would take for the top block to reach the end of where the lower block was initially, but it has moved on.
Thankyou! So I fixed my mistake by doing 3.05+X= (1/2)(3.817)(t^2) where x is the distance that the bottom block traveled and its equation is: x=(1/2)(.598427)(t^2) ( I got .598427 by doing 4.7575= 7.95a where 4.7575 is the friction force acting on the bottom block by the top block) and so I combined the two equations together and got T=1.3766seconds which turns out to be correct. Thank you for your tip!
Good.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
