How long does it take to boil away 0.4L water from a copper pot?
To determine how long it takes to boil away 0.4L of water from a copper pot heated to 195 °C, one must calculate the heat required for vaporization and divide it by the heat conduction rate through the pot's base. The calculations suggest a time of approximately 1.48 seconds, assuming no heat loss through the pot's sides. However, this result raises concerns about the feasibility of such rapid boiling in a small pot, potentially leading to explosive outcomes. The discussion emphasizes the need for practical considerations in theoretical problems, suggesting that consulting a professor may provide clarity on the scenario's validity.
Sam
This one has me stumped. Please help me solve.
Thank you!
Time
A copper pot is heated by a burner which is at 195 ° C. If the water in the pot is boiling, how long does it take in seconds to boil away 0.4 L? The diameter of the pot is 27 cm, and it is 3.5 mm thick.
k copper = 9.4 · 10^-2 kcal/(m · s ° C)
It's not too difficult if you can ignore any heat conducted up through the sides of the pot.
You have to determine the amount of heat needed to vaporize .4L of water, and divide by the rate at which heat is conducted through the copper base (assuming that the burner always supplies enough heat energy to maintain the outside temperature at the bottom of the pot at 195 degrees.
Can you do that?
I get 1.48 seconds. (Hope I haven't messed up the arithmetic.)
On the other hand, if conduction through the sides of the pot must be included, I don't think it can be done without knowing the depth of the water in the pot (but in that case I wouldn't know how to do it anyway ):smile:
Thanks
I did get 1.478607576 seconds, rounded to 1.48. I just forgot to take the thickness of the pot into consideration.
Thanks for the help.
Sam,
I arrived at the same answer, but this looks very suspicious to me: Boil away .4L of water in 1.4 secs in such a small pot? I call that an explosion.
Imagine you have your pot at 195°C, and pour in the water (let's say there's a bulk of hot material underneath so the water can't cool down the pot). What will probably happen is a big mess, after which you'll have to clean up the lab (if you're still alive ).
If I was you, I'd ask my prof what's the good of a problem like this.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
