How Many Fringes Shift in a Michelson Interferometer When Air is Evacuated?
The problem involves a Michelson interferometer and focuses on determining the number of fringes that shift when air is evacuated from a cell within one of its arms. The context includes the use of specific refractive indices for air and vacuum, as well as the wavelength of light used in the experiment.
  • Participants discuss the need to calculate the number of wavelengths that fit into a given distance under different refractive indices. There is mention of using a refraction formula to relate the wavelengths in air and vacuum.
Some participants have provided guidance on how to approach the problem, including hints about the round trip of light in the cell and the need to consider the difference in wavelengths due to the refractive indices. There is an acknowledgment of confusion regarding the teacher's instructions and the translation of concepts.
Participants note the lack of coverage of the Michelson experiment in their textbook and express uncertainty about the teacher's expectations. There is also a reference to the specific dimensions of the cell and the wavelength of light, which are critical to the problem but may not be fully understood by all participants.
Skye77
Here's my problem:
One of the arms of Michelson interferometer without the compensator consists of a cell 7.5 cm long. How many fringes would be observed shifting if all the air were evacuated from the cell? Use nvac= 1, nair= 1.00029 and the source wavelength 5,000 Angstoms (1 Angstrom = 10-10m) *Please see attached diagram for clarification*
I'm so confused as to what my teacher is asking. He hasn't covered Michelson's experiment and it's not in my textbook.
Also, I was given a hint: The light will pass twice through the cell due to the round trip. The answer will be obtained by counting the number of wavelengths to fit into the path difference between with and without air paths.
This was all he gave me. English is not his first language, so I'm not sure if I'm missing something in the translation, but any direction in how to solve this would be greatly appreciated.
Thanks.
A certain number of wavelengths will fit in the 15 cm when n = 1.00029.
A different number will fit in the 15 cm when n = 1 (no air).
You are asked for the difference between these two numbers.
The wavelength is given for air. Look for a refraction formula that you can use to calculate the wavelength when n = 1. The formula will have two n's and two λ's in it.
I'm still confused. :(
The wavelength is 5,000 Angstoms. How many of these fit in 15 cm?
It is like saying you have bricks 5 cm wide. How many will fit across your driveway which is 3 m wide?
Got it! Thanks so much for the help. I finally figured out what I was doing wrong. The difference is 87. I was forgetting to multiply the results by 1.00029 for the cell. Once I did that I got 300,087 for number of wavelengths through the cell versus 300,000 for the number of wavelengths through air where n= 1.0.
18K
