How many rotations of peddels per second?
  • Thread starter Thread starter mmoadi
    Per Rotations
A cyclist traveling at 18 km/h requires a pedal rotation rate calculated using the formula v = 2(pi)r * f. After converting the speed to 5 m/s and the wheel radius to 0.35 m, the initial calculation yields approximately 2.27 rotations per second. Considering the 2:1 gear ratio, the final calculation suggests that the pedals must turn 4.55 times per second. However, clarification on the gear ratio indicates that for every 2 rotations of the pedals, the rear wheel completes one rotation, leading to a corrected final answer of 1.14 rotations per second. The discussion emphasizes the importance of accurately interpreting gear ratios in bicycle mechanics.
mmoadi
A bicycle drives on a straight road with a velocity v = 18 km/h. How many turns (rotations) of peddles per second must be carried out by cyclists, if the radius of the wheels r = 35 cm, and the ratio of the radii of front and rear gear wheels is 2:1?
I used formula v=2(pi)r * f
So, I have another problem which says:
I converted: 18km/h = 5m/s and 35cm = 0.35m, so now we have all units unified.
I plugged the numbers into the formula and got the result f= 2.27.
And now we have the ratio 2:1, and since the the front gear wheel is larger than the rear one I multiplied by 2 and got the FINAL result which is 4.55 turns of peddles per second.
Are my calculations correct?
Thank you for all the help!
If the ratio of the gears is 2:1 doesn't that mean 2revs of the pedals to each rotation of the rear wheel?
So that mean that I have to divide by to and the correct final answer is f= 1.14?
Yes -
Twice the radaii on the front cog means that it rotates once for 2 rotations of the back cog (and hence the back wheel) - this is the normal gearing for a bike (except the lowest gear on a mountain bike) - I thought the question had claimed the opposite.
Thank you for your help!
