How much current does a 36 volt golf cart battery draw?
The discussion revolves around the current draw of a 36-volt golf cart motor under full load, exploring various factors that influence this measurement, including battery specifications and motor ratings. Participants also touch on related applications, such as converting a swamp cooler to run on batteries.
  • Experimental/applied
  • Some participants clarify that batteries supply current rather than draw it, suggesting the question pertains to the maximum current a motor can draw.
  • It is noted that the current draw depends on the specific battery and motor design, with comparisons made to different battery types, such as AAAs.
  • One participant emphasizes that the current drawn by the motor is variable and influenced by multiple factors, including the weight of the load and the design of the golf cart.
  • Another participant mentions that golf cart motors are typically rated by power (e.g., horsepower or kilowatts) rather than current, indicating a need for understanding power ratings in this context.
  • A participant shares personal experience with a 36-volt motor and discusses the feasibility of using batteries and solar panels for a swamp cooler, highlighting concerns about current draw and battery life.
  • There is a suggestion to start with data on the swamp cooler to determine its motor requirements.
Participants express differing views on the nature of current draw and the factors affecting it, indicating that the discussion remains unresolved with multiple competing perspectives on the topic.
Participants have not clarified specific assumptions regarding battery capacity, motor efficiency, or load conditions, which may affect the current draw calculations.
Keith H
Hello forum.
How much current does a 36 volt battery draw under a full load? (Scratch the word battery in this first sentence and replace it with motor). I know I could find it under manufacturers web sites, but I cannot seem to figure it out quickly.
Keith H said:
Hello forum.
How much current does a 36 volt battery draw under a full load? I know I could find it under manufacturers web sites, but I cannot seem to figure it out quickly.
I don't have the answer but I advise you that batteries don't "draw" current, they supply current, so I'm assuming you mean what is the maximum current can it supply.
I guess that depends on the battery. You won't get the current of a 36V golf cart battery out of 54 AAAs.
Agreed, but my nitpicker side can't help but point out that actually, yes you will, if the load is very small. You need to say that the max current out of 54AAAs isn't likely to equal the max current out of a golf cart battery. There is also the question of amp-hours which can be quite relevant to some questions but has not been clarified by the OP regarding his question.
phinds said:
Agreed, but my nitpicker side can't help ...
You're quite persistent on this, aren't you? :wink:
How much current would the motor use when under a full load in a Golf Cart?
Oh, yeah. Nitpicking is one of my better qualities. I don't even talk about the rest. :smile:
I guess I am wording it wrong. How much current is being used by a golf cart motor when the cart is loaded with four, fat golfers and all their stuff?
The current drawn by the motor is not a fixed amount that can be derived mathematically.
It is one of many parameters that would be taken into account by the designers of the golf cart, and not all golf carts are identical designs.
Some designs will be relatively lightweight machines not needing a very heavy duty motor, others easily capable of moving heavier loads.
So your question is a bit like asking how much fuel does it take to drive a car between two points A and B.
It depends on a lot of factors, but the main one is the design of the car and in particular the capacity of it's engine.
They are rated by power, not current. 5.5 hp, or 4 kW is typical.
I am trying to see how feasible it would be to convert a swamp cooler to run the squirrel cage fan using batteries with solar panels. I just discovered that a 36 volt 600 watt motor-scooter motor may just work.
Golf Cart motors can be 36 volt, but are 8 to 9 horsepower. My golf cart runs for 10 or more hours on six 6 volt batteries and three 40 watt 12 volt panels. I am not sure where all this is taking me, but I know that if I keep asking questions I will get it.
On Northern Tools website they list a Leeson 12volt motor that draws 58 amps on a full load. That would draw down my batteries far too fast.
My go-cart has a 36 volt Leeson motor. I run it for 2 1/2hours on three 12 volt 33ah batteries at full throttle.
If you want to power a swamp cooler start with data on the cooler.
The cooler demands a 1/2 hp motor or larger.
At what rpm?
12K
10K
  • · Replies 38 ·
68K
  • · Replies 24 ·
