How much energy will be released when the meteor hits Jupiter?
A meteor with a mass of 3.4 x 10^12 kg is set to collide with Jupiter, raising questions about the energy released upon impact. The discussion highlights the need to calculate gravitational potential energy using the formula U = -Gm_e m/r, comparing the meteor's energy at Jupiter's surface to its energy at infinity. Participants suggest using escape velocity to determine kinetic energy, leading to the equation K = GMM_J/R_J. The conversation emphasizes that both methods ultimately relate to gravitational potential energy. Understanding these concepts is crucial for accurately estimating the energy released during the meteor's impact on Jupiter.
odie5533
A meteor of mass about 3.4 x 10^12 kg is heading straight for Jupiter. When it hits there will be a huge release of energy, visible her on earth. Assuming it has fallen from far away, how much energy will be released when it hits Jupiter? The radius of Jupiter is 7 x 10^7 m and its mass is 1.9 x 10^27 kg.
A) 3.4 x 10&19 J
B) 5.8 x 10^18 J
C) 5.4 x 10^22 J
D) 6.8 x 10^19 J
E) 6.1 x 10^21 J
I'm somewhat lost as to how to approach this problem. When I've worked with energies, it has always involved velocity. In the chapter on gravitation in my text I only found mention of gravitational potential energy, U = -\frac{Gm_{e}m}{r}, but I don't have the distance between the masses. I'm guessing the collision would be inelastic, but I'm not sure how that helps. I can only think of ways of solving this if I'm given the velocity of the asteroid. Any help on this would be greatly appreciated.
After looking it over again, I think maybe I could use an integral.
W_{grav} = -Gm_{e}m\int_{r_{1}}^{r_{2}}\frac{dr}{r^2}
That is listed in our text.
So maybe...
W_{grav} = -Gm_{e}m\int_{\infty}^{0}\frac{dr}{r^2}
I don't think that's at all right. Just thinking aloud
If anyone has any ideas, any at all, please share. I'm turning this in completed or not in a few minutes. =/
Compare the gravitational potential energy of the meteor on Jupiter's surface with it's energy at r=infinity (where U=0). You don't need to integrate anything.
I asked my physics prof before class and he said to use the escape velocity in the kinetic energy equation:
V = \sqrt{\frac{2GM_{J}}{R_{J}}}
K = \frac{1}{2}MV^2 = \frac{1}{2}M\frac{2GM_{J}}{R_{J}} = \frac{GMM_{J}}{R_{J}}
Your way works better, and is easier to understand. Thanks :)
Sure. But it's the same thing. The calculation of escape velocity comes from potential energy. Which in turn is also the same thing as the integral you proposed earlier. Integrating the force over distance gives you the potential.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
