How much heat is released from water into ice.
  • Thread starter Thread starter ScienceGeek24
    Heat Ice Water
The discussion revolves around calculating the heat released when 250 g of water at 10 degrees Celsius freezes and cools to -10 degrees Celsius. The user initially miscalculated the heat transfer by not properly accounting for the different stages of the process: cooling to freezing, freezing, and cooling to the final temperature. After breaking down the calculations into three distinct stages and using the correct heat constants, the user arrived at a total heat release of approximately -2.177 x 10^5 J. The user expressed satisfaction after identifying and correcting their mistakes. The thread highlights the importance of careful stage-by-stage analysis in thermodynamic calculations.
ScienceGeek24
How much heat is released when 250 g of water at 10 degrees celcius freezes into ice and cools to -10 degrees celcius?
Q=mcΔt
q= (250g)(4186)(283-273)=1.046*10^4 J
than q=(250g)(2090)(263-283)=-1.045*10^4 J
when i subtract the two i get 1*10^4
The answer is -9.86*10^4 what am i doing wrong?
Three stages:
1. Cool to freezing point
2. Freeze
3. Cool to final temp
Each stage is governed by a different heat constant.
OK this is what I'm doing
1. cool to freezing point
q=(.250kg)(4186J/kgK)(273K-283K)=-1.046*10^4J
2.Freeze
MLf=(.250)(3.33*10^5)=8.32*10^4 J
3.Cool to final temp
Q= (.250kg)(2090j/kgK)(-283K-273K)=-2.90510*10^5
so when i sum up Q1+mLf+Q2= -2.177*10^5 J
Like seriously what am i doing wrong?
got it! i found the mistakes ! thanks! :D
