Automotive How much power is needed to haul a weight up an incline at a certain speed
To calculate the power needed to pull a 250lb load up a 45-degree incline at 5 mph, the gravitational force acting down the incline is approximately 175 pounds. This calculation focuses solely on overcoming gravity, ignoring air resistance and friction for now. It's important to clarify whether performing the power calculation is part of the assignment, as assistance is typically contingent on the requester showing prior effort. The discussion emphasizes the need for understanding the physics involved in the project. Engaging with the problem is essential for effective learning and application.
gmatt244
TL;DR Summary
Power needed to pull weight up an incline
Good afternoon everyone, I need help with a certain calculation. How much power is needed to pull a 250lb load up a 45 degree incline at 5 mph. I am working on a project at school and would like to know what kind of motor we can use. Thank you very much!
You have to overcome gravity and air resistance and rolling friction and axle friction.
Ignoring the last three for now, and just looking at gravity, it produces a force down the incline of
m(g sin theta) = (250/32)(32)(.707) or about 175 pounds. But before we talk about power, we need to know if doing the power calculation yourself is part of your assignment, because we don’t give homework help without your first showing an attempt. I already gave you a hint.
Likes anorlunda
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
