How much work does the earth do? help
  • Thread starter Thread starter ohheytai
    Earth Work
The discussion focuses on calculating the work done on a mass by the Earth and a spring in a physics problem. For part (a), the work done by the Earth is determined using the formula Work = Fd, where the force is the weight of the mass and the distance moved downward is 0.06 m, resulting in a positive value. In part (b), the work done by the spring is calculated by applying the work-energy principle, leading to a negative value since the spring's force acts upward against the downward displacement. The calculations involve understanding the relationship between force, displacement, and energy conservation. The thread emphasizes the importance of correctly applying physics formulas to solve the problem.
ohheytai
A mass of 0.105 kg hangs from a vertical spring in the lab room. You pull down on the mass and throw it vertically downward. The speed of the mass just after leaving your hand is 5.20 m/s.
(a) While the mass moves downward a distance of 0.06 m, how much work was done on the mass by the Earth? Include the appropriate sign
(b) At the instant in part (a) when the mass has moved downward a distance of 0.06 m, the speed of the mass has decreased to 3.74 m/s. How much work was done on the mass by the spring? Include the appropriate sign.
can someone help me? I've tried this twice and i missed it twiceee someone show me how please!
a) Work = Fd when they're in the same direction. So the force on the mass is mg (.105 x 9.8), and the distance it moves down is .06 meters. So solve for Fd (they're in the same direction so the answer is positive).
b) We'll write that the spring and Earth do work on the mass: so -1/2kx^2 + mgh = Net work
-.5 kx^2 + mgh (the solution to a) = 1/2m(vf)^2 - 1/2m(vo)^2. All you have to do is solve for -.5 kx^2. The work is negative because the displacement is downwards and the force is upwards.
ok thankss!
