How much work is done on a gas?
  • Thread starter Thread starter Chele
    Gas Work
In a thermodynamics problem involving a monatomic ideal gas, 4390 J of heat is released, and the temperature remains constant. The key equation used is ΔE = Q - W, where Q is negative due to heat leaving the system. Since the temperature is constant, ΔE equals zero, leading to the conclusion that W equals 4390 J, indicating work is done on the gas. The discussion clarifies the sign convention for work, emphasizing that in this context, W represents work done on the system. Ultimately, the correct answer is W = 4390 Joules.
Chele
First of all...thanks for any help. This is ultrabasic introduction to therm, so I know everyone says that no question is stupid, but I just feel like I'm really missing the boat here.
The temperature of a monatomic ideal gas remains constant during a process in which 4390 J of heat flows out of the gas. How much work (including the proper + or - sign) is done on the gas?
\DeltaE=nCv\DeltaT
and I think...maybe
\DeltaE=Q - W
Since it says that the temperature remains constant, I was thinking that \DeltaE=0
Q is the heat supplied TO the system, so if 4390 J of heat came out, then it would be -Q.
So I figured that:
\DeltaE=Q - W
0=-4390 - W
W=-4390 Joules
That's not correct. They must be telling me that it's a monatomic ideal gas for some reason.
HELP!
Sign convention
Chele said:
\DeltaE=Q - W
Realize that in this equation:
Q = the heat energy transferred into the the system
W = the work done by the system (on the environment)
So the work done on the system is just the negative of that.
Many modern books use this form of the first law:
\DeltaE=Q + W, in which W is the work done on the system. This form makes it clearer that this is just a statement of energy conservation.
Thank you...obviously I was looking at the meanings incorrectly.
The answer is W=4390 Joules.
The way you worded your answer actually helps me with yet another problem I was having! Have a great day!
