I How reduced density matrix obtained from the matrix.
munirah
Can any expert help me in explaining how this example below get the reduced density matrix from the density matrix in bipartite system.
$$\rho =\frac{1}{4}\begin{pmatrix} 1 & 1 & cos(\frac{\alpha}{2})-sin(\frac{\alpha}{2}) & cos(\frac{\alpha}{2})+sin(\frac{\alpha}{2}) \\ 1 & 1 & cos(\frac{\alpha}{2})-sin(\frac{\alpha}{2}) & cos(\frac{\alpha}{2})+sin(\frac{\alpha}{2}) \\ cos(\frac{\alpha}{2})-sin(\frac{\alpha}{2}) & cos(\frac{\alpha}{2})-sin(\frac{\alpha}{2}) & 1-sin(\frac{\alpha}{2}) & cos(\frac{\alpha}{4}) \\ cos(\frac{\alpha}{2})+sin(\frac{\alpha}{2}) & cos(\frac{\alpha}{2})+sin(\frac{\alpha}{2}) & cos(\frac{\alpha}{4}) & 1+sin(\alpha)\end{pmatrix}$$
For the subsystems, this yields, as below.
$$\rho_\text{A}=Tr_\text{B}(\rho)=\frac{1}{2}\begin{pmatrix}1 & cos(\frac{\alpha}{2}) \\ cos(\frac{\alpha}{2}) & 1\end{pmatrix}$$
and
$$\rho_\text{B}=Tr_\text{A}(\rho)=\frac{1}{2}\begin{pmatrix}1-\frac{1}{2}sin(\alpha) & cos^2(\frac{\alpha}{2}) \\ cos^2(\frac{\alpha}{2}) & 1+\frac{1}{2}sin(\alpha)\end{pmatrix}$$
How the reduced to each system A and B obtained?
If you have a composite density of the form
\rho_{i j a b}
where i, j refer to a basis for system A and a, b refer to a basis for system B, then
(\rho_A)_{i j} = \sum_a \rho_{i j a a}
(\rho_B)_{a b} = \sum_i \rho_{i i a b}
Your 4x4 matrix doesn't clearly indicate which indices are for A and which are for B, but I assume you're doing something like:
  1. The element with row=1, column=1 corresponds to i=1, j=1, a=1, b=1
  2. The element with row=1, column=2 corresponds to i=1, j=1, a=2, b=1
  3. The element with row=2, column=1 corresponds to i=1, j=1, a=1, b=2
  4. The element with row=2, column=2 corresponds to i=1, j=1, a=2, b=2
  5. The element with row=1, column=3 corresponds to i=2, j=1, a=1, b=1
  6. The element with row=1, column=4 corresponds to i=2, j=1, a=2, b=1
  7. The element with row=2, column=3 corresponds to i=2, j=1, a=1, b=2
  8. The element with row=2, column=4 corresponds to i=2, j=1, a=2, b=2
  9. etc.
(or something like that)
Likes munirah
\rho_{i j a b}
  9. etc.
thankyou for helping me. really appreciate.
Sorry, I want to ask more either the notation for
or
(\rho_A)_{i j} = \sum_a \rho_{i j a b} ?
Thank you very much
or
Thank you very much
The first one is correct. That's sort of obvious, because the second one has a free index, b on the right-hand side, but not on the left-hand-side.
Likes munirah
tqvm stevendaryl for your respon
stevendaryl, can you give me the example according what you explain. I already try to understand. please
You have to give the context. There's no way to guess from just throwing a matrix in the discussion what it means! There must be a clear definition in the textbook/problem sheet given. Otherwise it's just useless!
I don't understand what it is that you don't understand. The density matrix for a two-component system has 4 indices: two for the first component, and two for the second component. To form the reduced matrix for one component, you "trace" over the indices for the other component. A trace means setting the two indices to the same value and summing over all possibilities.
Your original matrix doesn't clearly identify those 4 indices, so it's not possible to form the reduced matrix without additional information. That was probably present, if you saw the problem in a textbook.
From your 16-element matrix, what I'm assuming the components of \rho_{ijab} are:
  1. \rho_{1111} = \frac{1}{4}
  2. \rho_{1112} = \frac{1}{4}
  3. \rho_{1121} = \frac{1}{4}
  4. \rho_{1122} = \frac{1}{4}
  5. \rho_{1211} = \frac{1}{4}(cos(\frac{\alpha}{2}) - sin(\frac{\alpha}{2}))
  6. \rho_{1212} = \frac{1}{4}(cos(\frac{\alpha}{2}) + sin(\frac{\alpha}{2}))
  7. \rho_{1221} = \frac{1}{4}(cos(\frac{\alpha}{2}) - sin(\frac{\alpha}{2}))
  8. \rho_{1222} = \frac{1}{4}(cos(\frac{\alpha}{2}) + sin(\frac{\alpha}{2}))
Etc.
So
(\rho_A)_{ij} = \rho_{ij11} + \rho_{ij22}
(\rho_B)_{ab} = \rho_{11ab} + \rho_{22ab}
Likes munirah and vanhees71
tqvm stevendaryl. I understand now
