How Should Wind Turbine Blades Be Designed for Maximum Efficiency?
The discussion centers on designing wind turbine blades for maximum efficiency, particularly for a miniature model in an engineering competition. An optimal design includes three blades to ensure balance and stability. While airfoil shape is important, the length of the rotor blades significantly impacts energy capture, with larger blades used in commercial turbines. Concerns are raised about using cardboard for construction, as it may not withstand environmental factors, but it is deemed acceptable for a model that won't face harsh conditions. Ultimately, the focus is on balancing design efficiency with practical material constraints.
lukedimarco
We are looking to effectivley build a wind turbine to capture the wind and create energy. What would be the most effective and easisest way to construct the windmill?
I would like to focus on the design of the blades themselves. What design of the blades would provide maximum support and energy? I am aware that an odd number of blades (3 is ideal) is great because then the windmill will always even out.
What are we thinking? This would most likely me manufactured from cardboard.
What size are we talking about here?
By "design of the blades" are you referring to the airfoil? You can find airfoils that are currently used for wind turbines here.
http://www.ae.illinois.edu/m-selig/ads/coord_database.html
But I don't know how you would build a turbine blade out of cardboard. And for that matter it seems like building a wind turbine out of cardboard is a bad idea all around. I would expect it to just blow away or get ruined in the rain.
It is a miniature model for a engineering competition. Doesn't need to withstand elements. They are giving us materials and a time, I have heard that most of the materials are cardboard and tape.
Airfoil plays a role, but the main factor in efficiency is the length of each roter blade. This is why wind turbines at wind farms use such huge rotor blades on their windmills (20 to 40 meters). This isn't pratical everywhere, so smaller designs are used:
http://en.wikipedia.org/wiki/Wind_turbine
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
