How to achieve a zero resistance on a force sensitive resistor?
To achieve near-zero resistance on a force sensitive resistor (FSR) when pressure is applied, modifying the sensor's characteristics is not feasible. Instead, incorporating a circuit with a MOSFET that has low on-resistance can simulate this effect. The gate of the MOSFET should be connected to a voltage divider formed by the pressure sensor and an additional resistor. This setup allows the FSR to control the MOSFET, effectively creating a low-resistance path when pressure is applied. Implementing this circuit design can help achieve the desired functionality.
mikepny
Hi all,
I've a square force sensitive resistor with a resistance larger than 1MΩ when no pressure is applied. When I apply pressure with my hand, the resistance drops to about 480kΩ
I'd like to know if there is a way to make the resistance drop to almost 0Ω when any pressure is applied and return to normal when the pressure is released?
Thanks
You aren't going to be able to change the characteristics of the sensor but you can add a circuit that appears like approximately zero ohms when pressure is applied. I would start with a mosfet with a low on resistance, with the gate connected to a voltage divider of the pressure sensor and a resistor. The pressure sensor should be between the gate and Vcc.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
