How to amplify voltage to meet the needs of a photodiode/APD
  • Thread starter Thread starter Robert Dietrich
    Voltage
To power two photodiodes requiring a bias voltage of at least 40V for scintillation detection, a lightweight battery solution is essential for a weather balloon project. Using op amps to amplify voltage from a 9V battery may lead to rapid battery drain, as op amps need a power source equal to or greater than the desired output voltage. The specific photodiodes can operate at lower reverse voltages, such as 3.5V, which may be more efficient. Voltage doublers or triplers could be considered for achieving the necessary voltage without excessive power consumption. Careful consideration of the photodiode specifications and circuit design is crucial for successful implementation.
Robert Dietrich
I need to be able to run two photodiodes that require a bias voltage of at least 40V (this might need to be a little bigger, as I'm planning on using them for scintillation detection). They need to be able to run for two hours off of a lightweight battery. This is because they will be on a weather balloon for a long ride (this is my senior seminar project) and the weight of the payload can't be too high.
N/A
I was thinking of using a series of op amps, but I'm concerned that simply using op amps to increase the output voltage of (for example) a 9V battery will drain the battery too quickly. A link to the specific photodiodes I'm using is http://www.mouser.com/ProductDetail/First-Sensor/PS10-5B-TO52S13/?qs=sGAEpiMZZMt9rZLnhhqRzxxh2B7IPT45
The data sheet for that photodiode (at the site you reference) shows that 40V is the peak reverse voltage for that part. Are you sure you want to exceed that?
A brief web search on photodiode circuit examples turned up something that might be of interest here. Check out items 9 and 10.
For an opamp to produce a 40 V output its power source must already be equal to or greater than 40 V unless you're doing something with current pumps (voltage doublers or triplers).
Your photodiode is specified to work at 3.5V reverse voltage with a bit better bandwidth at 20V. Most probably works fine at 3.5V.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
