Automotive How to calculate 1.5 order wheel torque fluctuation (3 Cylin
The discussion focuses on calculating the 1.5 order wheel torque fluctuation using raw data that includes engine speed, wheel torque values, and main shaft speed. The user seeks assistance in developing a logic or formula to derive the 1.5 order wheel torque value that aligns with a provided result. Clarifications are offered for any uncertainties regarding the data. The user emphasizes the collaborative nature of the forum for research-related inquiries. Overall, the goal is to find an accurate method for calculating the desired torque value.
Chethan K S
Hi all,
I have the raw data in .csv file which has Engine speed, wheel torque value and main shaft speed (Please refer to below image - raw data_screen shot)
I have to find the logic for the above raw data, to get 1.5 order wheel torque value, which is close to resulted value as attached (Result_1.5 order torque value as shown below).
I am working on this, I request all members of research gate forum to help me on this to create a logic/formula.
If the above information is not clear enough, please ask me
Many thanks,
CKS
What's a "research gate forum"?
This forums will be having many research people. So I requested them by saying research group/gate, etc
Sorry if I am wrong
CKS
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
